Radomness Of Brick - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-17-2006, 04:07 PM   #16
Rewards Points: 562
Originally Posted by Tscarborough View Post
It is not an error, it is poor training. If you were to take it to court, you would lose.
If it's not done properly then why would I lose?
kcrossley2 is offline   Reply With Quote
Old 12-17-2006, 04:09 PM   #17
Rewards Points: 1,232
On a brick that is highly variable, there is no standard that determines the "pattern" of brick laid. In some cases, commercially, there is a specification written to address this, but for residential work there generally is none.
Tscarborough is offline   Reply With Quote
Old 12-17-2006, 04:12 PM   #18
What it boils down to is purely subjective, and the fact that some masons take the time and effort to do it "right" has no bearing on the fact that others do it within the specifications of the work, only.
Old 12-17-2006, 04:39 PM   #19
Rewards Points: 562
Yes, but like you said the model home was done properly and my foundation was not. It seems like that would be enough to prove my case. By the way, I have no intent of taking this to court. However, I may decide not to close on the home until this issue is resolved. The bottom line is that I do have some leverage here, but I also want to be reasonable.
Actually, you know what would cover up the pattern error nicely? How about a nice deck? That has to be cheaper than ripping it out and starting over?
Old 12-17-2006, 04:47 PM   #20
You have all the leverage in the world. You do not have to accept the home. What I am telling you is two-fold:
If it goes to court on this issue, you will lose, period. The brickwork is acceptable as laid (provided it meets all the written specifications, which I am sure it does).
You can certainly bail on the house for this and other reasons with a minimal cost to you.
Old 12-17-2006, 04:54 PM   #21
Rewards Points: 562
Like I said before, I'm sure this can all be worked out. It is the back of the house so perhaps it's not a big deal.
Old 12-17-2006, 05:24 PM   #22
Trust me, it is not a big deal. Like I said earlier, 90% of the people will not notice, and 99% will not notice enough to care.
I would save my fights for things that DO matter.
Old 12-20-2006, 05:59 PM   #23
Only seeing the pics and not being on site, I would complain.
CJKarl is offline   Reply With Quote
Old 12-20-2006, 06:00 PM   #24
Shrubs
Old 12-20-2006, 10:36 PM   #25
Rewards Points: 562
The project manager saw the work and agreed, so it's being replaced.
Old 12-21-2006, 05:08 PM   #26
Excellent!
Old 01-01-2007, 12:42 PM   #27
I finally remembered to bring home and scan a brick label:
http://72.41.69.75/bricklabel.jpg
Old 01-01-2007, 01:16 PM   #28
The model home sure is a beauty!
Not Sure is offline   Reply With Quote
Old 01-01-2007, 01:59 PM   #29
Rewards Points: 562
I finally remembered to bring home and scan a brick label: http://72.41.69.75/bricklabel.jpg
Hey, thanks for doing that.
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 12:11 AM
Cheaper masonry alternatives to brick? Jemo Building & Construction 9 05-18-2007 12:31 PM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 10:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 07:17 AM
