Radiant Barrier + Insulation With Metal Roof - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2010, 05:21 PM   #1
Radiant Barrier + Insulation with Metal Roof
Hi,
So I've spend hours and hours and hours researching insulation in an attempt to educate myself and also to finaliz my building material list for my 30'x40' workshop. I need some expert advice. Right now, I've decided to go with a combination of Prodex radiant barrier (non perforated so serves as a vapor barrier too installed under the purlins (1.5" air space gap) of my metal roof + R19 batting + R10 2" polyiso foam panels.
I want to ensure that this particular combination of materials will be effective for insulation, moisture and radiant barrier. Would you mind look at the image & pointing out any concerns? I'm most concerned about the batting installed in between the 2" polyiso board and the radiant/vapor barrier.
Ultimately, when you look up at the roof you will see the polyiso board. I'm not finishing further. Hoping this will provide good insulation characeteristics. I'm located in Austin, TX so the summers are quite brutal and we do get humid at times.
Radiant Barrier + Insulation with Metal Roof-roof-insulation-diagram-copy.jpg
customfab is offline   Reply With Quote
Old 02-15-2010, 05:35 PM   #2
Love for Construction
<*(((><'s Avatar
How is the roof going to vent with the R-19 blocking the path?
<*(((>< is offline   Reply With Quote
Old 02-15-2010, 07:54 PM   #3
Tom Struble's Avatar
Rewards Points: 2,002
actually air moves pretty good thru the edges of batt insulation,those edges should be blocked off
what would concern me is having the fg in between 2 vapor barriers
Tom Struble is offline   Reply With Quote
Old 02-15-2010, 08:46 PM   #4
Registered User
Rewards Points: 5,482
In more moderate climates, the condensed water could evaporate and pass through the radiant barrier into the attic space. While most uniform aluminum coatings do not allow water vapor to pass through them, many radiant barrier materials do allow passage of water vapor. Some allow water vapor passage through holes or perforations, while others have substrates that naturally allow water vapor passage without requiring holes. However, excessively large holes will increase the emissivity and cause a reduction in the radiant barrier performance. The ability to allow water vapor to pass through radiant barrier materials is not needed for the roof applications.
A radiant barrier reduces the amount of heat radiated across an air space that is adjacent to the radiant barrier. The primary function of conventional insulation is to trap still air within the insulation, and hence reduce heat transfer by air movement (convection). The insulation fibers or particles also partially block radiation heat transfer through the space occupied by the insulation. From: http://www.ornl.gov/sci/roofs+walls/radiant/index.html
http://docs.google.com/viewer?a=v&q=...oCq-P91xd-Qiaw
http://www.gravesroofing.com/Insulation.htm
Careful of the fasteners: http://www.eco-structure.com/cool-ro...hats-cool.aspx
Polyiso vs. XPS: http://www.roofingcontractor.com/CDA...00000000484938
The radiant barrier is in the correct spot, the foam is not.
Be safe, Gary
Old 02-16-2010, 07:20 PM   #5
Be safe, Gary
Gary,
Could you elaborate on this further for my education?
Old 02-16-2010, 07:22 PM   #6
"fg"?
Sorry, my drawing for the soffit vents isn't accurate. The foam board certainly would not be blocked vent flow.
Old 02-16-2010, 08:12 PM   #7
jlhaslip's Avatar
Rewards Points: 1,498
What thickness is the R-19 Batt insulation?
I'm not familiar with that, but it might be the stuff we put into a 2 x 4 wall.
That should allow 2" (+/-) above it for ventilation?
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-16-2010, 08:25 PM   #8
Registered User
Picture on page 3: http://danperkinsroof.com/1108_JCL_Perkins_A.pdf
Be safe, Gary
Old 02-16-2010, 09:47 PM   #9
Originally Posted by customfab View Post
"fg"?
fiberglass
in your illustration air could flow thru the ends of the fiberglass
reducing its effectiveness ,the ends and sides should be blocked off from airflow
use a perforated radiant so any moisture can get thru to be vented
you could go with a product that specially designed for your type of project
http://www.insulation4less.com/
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 12:18 AM
Radiant barrier with faced insulation? luci468 Building & Construction 1 07-18-2009 03:49 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Metal roof??? Tdoggy187 Roofing/Siding 51 03-04-2008 03:35 PM
Metal versus Traditional Shingle Roof 4powells Building & Construction 2 04-28-2005 09:40 AM
