R30 Ceiling Insulation With 2x4 Roof Trusses - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2008, 01:58 PM   #1
R30 ceiling insulation with 2x4 roof trusses
I was wondering if someone could advise me on how to properly install r30 insulation (rolled or blown) on the ceiling of a new addition that is using trusses with 2x4's.
(location is northeastern Ohio if it matters)
I wanted to use blown insulation but wasn't sure how to do it with drywall having to wait until after the insulation inspection.
I_think_I_conduit is offline   Reply With Quote
Old 04-04-2008, 02:55 PM   #2
Custom Cabinet Maker
You can't.Use batt insulation.
skymaster is offline   Reply With Quote
Old 04-04-2008, 03:25 PM   #3
Why??
jerryh3 is offline   Reply With Quote
Old 04-04-2008, 03:37 PM   #4
concretemasonry's Avatar
Rewards Points: 2,626
Just blow in cellulose!!
Fiblerglass is an ineffective insulation with many problems.
You will get total coverage and minimize the thermal shorcircuiting caused by the wood. If you are into the old R-value concept cellulose is also better.
Only the pink panther thinks it is better and he gets paid for doing that.
concretemasonry is offline   Reply With Quote
Old 04-04-2008, 03:43 PM   #5
In n.e. ohio ,I would suggest r38. It may be code .Or 12" of blown in.Inspector will come for 2nd insulation inspection when your blown in is completed
johnrem is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Flat Roof Construction- insulation EricC Roofing/Siding 15 12-02-2007 08:49 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
