R2000 Home And Humidity - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-13-2010, 01:53 PM   #1
R2000 Home and humidity
Hello all, We recently purchased a 3 yr old home , it is 1,400.00 (apx) square foot on the main level and basement is unfinished, the house is equipped with an VanEE air exchanger , however we are not using it at the moment, we did just put in a 2 and 1/2 ton central air unit, ( according to the specs this is the apropriate size) we have been able to get the humidex reading down from 82 percent to 70 using the dehumidifer in the basement and the CA turned to 72 degrees, but* we cant get the humidex reading below 68 0r 69 percent,
is it acceptable to have humidex readings this high? and does anyone have any suggestions as to how to get it lower if it is not acceptable, at least the bed sheets and furniture does not feel damp now as it did when we moved in
also is this always going to be a problem with an air tight home?
Rene2 is offline   Reply With Quote
Old 07-13-2010, 05:07 PM   #2
joed's Avatar
Rewards Points: 12,918
The HRV should be running always. An R2000 house is too well sealed for air exchange. That is why they install HRV in these homes.
Old 07-14-2010, 12:27 AM   #3
Rewards Points: 410
2.5 ton sounds way oversized for the sq footage in an energy efficient house.
High Gear is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
High Humidity in Home jamiedolan HVAC 7 07-10-2010 12:27 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
best way to lower humidity in home brian2 HVAC 6 01-24-2007 12:55 PM
