R19 Insualtion In 2x4 Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-30-2010, 10:44 AM   #1
R19 insualtion in 2x4 wall
While finishing my attic, I added 1" extruded polystyrene to the backs of the 2x4 knee walls. However, when doing this, I noticed the builder placed R-19 in the 2x4 knee walls. From a chart I found online, the compressed R-19 will provide R-13 insulation value. Therefore, I am considering leaving the R-19 in place since it proved the same R-value as replacing it with R-13. Any suggestions or comments?
SOCON is offline   Reply With Quote
Old 11-30-2010, 10:55 AM   #2
Rewards Points: 5,336
You can buy R15 batts for the 2x4 wall and the foam borad. As a head's up, you're supposed to cover the foam with sheetrock as it will burn and give off toxic smoke.
Ron
Old 11-30-2010, 11:59 AM   #3
concretemasonry's Avatar
Rewards Points: 2,640
The R-value is just the insulation value of the stuff between the studs/joists and not a acurate measuement of the wall/ceiling R-value. The wood studs will cut the wall insulation value by 10 to 20%. - Even much more with steel studs. - This is just for short term advertising numbers and do not accurately reflect the longer term properties that also relate to mass and weather cycles. Extruded polystyrene board is good at minimizing the thermal short-circuiting of the studs, since it is a continuous barrier and does not permit infiltration.
Dick
concretemasonry is online now   Reply With Quote
Old 11-30-2010, 04:14 PM   #4
Registered User
Rewards Points: 526
I would leave it be. The compression means it is now denser than before, unable to have convective loops within it, the same as the denser R-15. If you can meet all 5 requirements in 4.2.1.2 here, you may not have to cover the board. Air space above sloped ceiling to upper attic- need to cover it; http://www.hcpdc.com/pdf/Dryer%20Ven...quirements.pdf
Be sure to close the floor bays and the end of upper insulation between rafter bays to prevent wind-washing; below vents: http://www.simplesavings.coop/simple...ee%20walls.pdf
Gary
Tags
insulation; foam; wall
Cutting through masonry wall mwpiper Remodeling 4 04-17-2010 10:30 AM
building a wall against an exterior wall Mike L General DIY Discussions 2 08-20-2009 02:50 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
