R13 Or R19?? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 10:42 AM   #1
R13 or R19??
My local building code only requires R13 on 2x4 walls. Would it be wasteful to go R18 with the foam sheets. It's also $800 more.
EC1970 is offline   Reply With Quote
Old 01-11-2011, 11:32 AM   #2
Experienced
Jackofall1's Avatar
That is kind of like asking, would leaving the car running over night instead of turning it off make a difference with gas consumption.
What material are you thinking of using to insulate, have you looked at all the options?
You could try buildingsceince.com for insulation methods and materials.
The Following User Says Thank You to Jackofall1 For This Useful Post:
EC1970 (01-11-2011)
Old 01-11-2011, 01:54 PM   #3
WaldenL's Avatar
Rewards Points: 268
Clearly the R18 will insulate better, but the question is, is it worth it? Is this for the entire house, or just an extension/new wall? How tight is the rest of the house? Does it leak energy like a sieve or is it really tight? From a financial worth question you've got to ask yourself how long will it take for you to save that extra cost in energy. If you'll save $100 / year is a 8 year payback ok with you? If it's $10/year is an 80 year payback ok? Of course there are other measures of worth, will you sleep better at night knowing you're saving energy?
WaldenL is offline   Reply With Quote
The Following User Says Thank You to WaldenL For This Useful Post:
EC1970 (01-11-2011)
Old 01-11-2011, 02:34 PM   #4
Rewards Points: 6,652
Anything over R-13 when placed into a 2x4 stud space will compress down to R-15. Best would be recycled Blue Jeans, or RoxWool, or even WetSpray Mineral, which would be even better than placing Batts of any other insulation. Fiberglass has less insulating & sound deading properties, than Spray in, or recyled bluejeans, roxwool, wetspray Mineral/Roxwool.
The Following User Says Thank You to gregzoll For This Useful Post:
EC1970 (01-11-2011)
Old 01-11-2011, 02:49 PM   #5
rditz's Avatar
When I have been doing our farm house, the studs are true 2x4's so I have an extra 1/2" of cavity depth. what I did was first put in 1/2" rigid styrofoam for a R0.5 and then R14 Roxul... this works out well and fills the cavity up.
rod
rditz is offline   Reply With Quote
The Following User Says Thank You to rditz For This Useful Post:
EC1970 (01-11-2011)
