Old 08-14-2009, 01:56 AM   #1
quikrete deck forms
I am using quikrete concrete mix for deck footers. How long after I pour the footers, can I actually start building the frame on them?? I was thinking a day, but do I need to wait until they totally cure? The footers are 3feet deep, 8in wide.
Also note, I wont actually put the rest of the decking/railing on for at least a week or so (work constraints/weekend activities!).
Thanks in advance.
redroc25 is offline   Reply With Quote
Old 08-14-2009, 02:29 AM   #2
Renovation Contractor
Paragon's Avatar
quikrete deck forms
So why not just set the posts and call er good because if you plan on setting the frame you may tend to rush the job?
James D. Van Raden
Owner, Paragon Renovations Moorhead, MN/ Fargo, ND
"Committed to providing the finest renovation services available"
Paragon is offline   Reply With Quote
Old 08-14-2009, 07:58 AM   #3
General Contractor
quikrete deck forms
Concrete reaches it's maximum psi in 28 days. We frame our decks on temporary supports so as not to get held up waiting for inspections and curing times. Normally for the application you are doing we allow 24-72 hours before removing the temporary supports. Note if your building on columns make sure they are 6" above finish grade and use stainless steel post brackets and fasteners type 304 or better.
ARI001 is offline   Reply With Quote
Old 08-14-2009, 10:13 AM   #4
Moderator
Termite's Avatar
quikrete deck forms
Originally Posted by ARI001 View Post
....use stainless steel post brackets and fasteners type 304 or better.
Stainless? Although that would be the best/ideal product I'm unaware of a requirement for stainless hardware. Is there one in your locality ARI001? I can see it being more important in saltwater environments but around here we never see stainless deck hardware.
redroc25, I'd have no concerns with building on the posts 48 hours after they're placed. The concrete will get stronger over time and reaches the majority of its strength after a month. Just give it a few days before having a party for 30 of your friends on the deck.
Old 08-14-2009, 10:32 AM   #5
Thumbs up
quikrete deck forms
Thanks for your help, this has helped. As a DIY'er on this project, dont know why I didnt think of the temp supports.
As for the brackets, they are required here for the code, so all your answers helped/appear reasonable!
Enjoy your weekend, I'll be back.
Thanks again for your quick response.
Adam
Old 08-14-2009, 11:27 AM   #6
General Contractor
quikrete deck forms
KC,
It depends on where you are working in the state as to whether or not stainless is required. I use them on columns because of corrosion issues associated with copper and galvanized treated fasteners. That is not a bracket you want to have to replace 6 months down the road. If it's not required in the locality I am working I leave it up to the client as far as the rest of the hangers and fasteners. If they want to upgrade I will, if they don't I'll install galvanized. If they opt to use galvanized I do have a disclaimer stating that the preservatives in the wood can cause premature fastener and hanger failure and that it is their responsibility to inspect the structure at regular intervals for signs of fastener failure. Obviously we will only replace fasteners and hangers that corrode during the warranty period.
Old 08-14-2009, 12:26 PM   #7
Moderator
Termite's Avatar
quikrete deck forms
ARI001, got it. Makes sense to use them in the impossible-to-replace locations such as post bases. I'd sure hate to get the bill for how much stainless bases cost though!
Tags
construction, deck, footer, quikrete
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 06:07 PM
Post detail for raised covered deck jogr Building & Construction 3 05-16-2009 08:46 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
What size deck is 'good' for our situation? curls00 Carpentry 20 09-08-2007 08:12 PM
