Old 08-08-2010, 12:40 AM   #1
Quiet Rock vs Green Glue
Building a drum room in my garage (18x11). I'm not 100% sure about using sound isolation clips and hat channels. Thinking about using R-19 Ultra Touch Cotton Insulation (STC 57) (walls and roof rafters) and 2 layers of sheetrock with 3 tubes of Green Glue in between, or QuietRock 525 over the "blue jean" insulation. Boarded up the windows and removed garage door and installed 36x80 wood door. Opinions, recommendations?
drummer2020 is offline   Reply With Quote
Old 08-08-2010, 12:35 PM   #2
Soundproofing Guy
Decouple the walls with framing not clips
Use standard insulation. There is no data that says cotton is better.
Make the walls and ceiling as heavy as possible with double 5/8" drywall. Just standard, cheap but heavy drywall. The added mass will provide great assistance in helping control the low frequencies.
Field apply damping compound
Ted White is offline   Reply With Quote
Old 08-08-2010, 09:15 PM   #3
Thanks Ted. Can you explain decoupling walls with framing rather than clips. Is this adding a second wall?
Do you have an opinion about using DUROCK® cement board Next Gen over the wood studs and then 2 layers of 5/8 drywall with 2-3 tubes of Green Glue?
Also, any suggestions on sound damping the garage concrete floor?
Old 08-09-2010, 09:13 AM   #4
Soundproofing Guy
Here's an article describing room within a room construction: http://www.soundproofingcompany.com/...within_a_room/
The second wall would provide the decoupling, rather than the clips.
Regarding the cement board, you could do that, however the cement board is simply more mass. I'd stick with drywall as it's easier, faster and cheaper.
I'd leave the garage floor alone, as it is already massive.
Old 08-10-2010, 11:59 PM   #5
Moderator
What do you think of this, Ted? http://www.certainteed.com/resources...%20Control.pdf
I know they are biased and possibly with a grain of salt on the ratings?
Be safe, Gary
Clothes taking longer to dry?
Old 08-11-2010, 08:37 AM   #6
Soundproofing Guy
It's a good general guide. They depend heavily on STC ratings, which do not include low frequencies. The problem is that a "high STC" wall will likely not satisfy in the real world. The most common complaints are with sound that is below what STC measures. This would be bass.
The Following User Says Thank You to Ted White For This Useful Post:
Gary in WA (08-11-2010)
Adding green glue and 5/8" Bigmike33 Drywall & Plaster 5 06-17-2010 10:04 PM
Quietrock and Green Glue for soundproof ceiling Isaac Clarke Drywall & Plaster 19 05-18-2010 03:58 PM
do i have to remove old adhesive glue on wall for new ceramic with glue? Limit54 Tiling, ceramics, marble 2 03-01-2010 11:12 PM
Green is the New Black aaron.klimchuk Green Home Improvement 36 02-17-2009 10:07 AM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 01:11 AM
