Quick And Cheap Way To Fix A Bad Cement Driveway? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-07-2010, 06:37 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Quick and cheap way to fix a bad cement driveway?
My driveway is basically two slabs with some "sidewalk" like indentations and both pieces are splitting away down the middle due to ground movement and what not. This makes shoveling very hard in the winter for the first few months, until I manage to have a smoother hard snow surface over the crack.
What is a quick and cheap way I can smooth this out, that would last a few years at least? I'm thinking of just cleaning up the crack of debris, dig to the thickness of the slab, maybe more, adding a bit of rebar at the bottom, and putting in some cement and leveling it out. I know this will not last, and the proper way to fix would be to basically remove it all, and pack the ground better, but I just want this to last a few years till I can get the driveway redone professionally. Probably have to dig a couple feet to make a proper "foundation" and this was not done for this one.
Old 10-07-2010, 06:40 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... How big a Crack,..?? I'd probably just skip the rebar...
Bondo is online now   Reply With Quote
Old 10-07-2010, 07:16 PM   #3
Wire Chewer
Rewards Points: 132
Maybe 4-5 inches. I'm sure it will seperate some more, but even if I just have a hairline crack after going through the winter, it's still better then something I can twist my angle on, fall down, and crush my skull, or worse, have it happen to the mailman and get sued.
Old 10-07-2010, 07:28 PM   #4
joed's Avatar
Rewards Points: 13,346
Unless you rebar the two slabs together you will be lucky if it lasts one winter.
Old 10-07-2010, 10:53 PM   #5
Rewards Points: 1,910
Quick and cheap? Just spray some water on it as soon as it's cold enough. It will freeze nice and level. If you get a warm spell you might need to repeat but water's cheap.
Sorry RS I couldn't resist.
Old 10-08-2010, 05:40 AM   #6
Rewards Points: 4,750
scarifiers grind & level concrete,,, leaves a corduroy surface texture you'll only find them at const rental yards UNLESS you're very lucky.
Old 10-08-2010, 07:30 AM   #7
Wire Chewer
Rewards Points: 132
Actually last year I just packed it with snow, it got hard over time.
Old 10-08-2010, 09:17 AM   #8
Not sure of your definition of cheap, but have you priced blacktop?
Pistol Pete is offline   Reply With Quote
Old 10-08-2010, 09:40 AM   #9
Rewards Points: 558
Patch the cracks with concrete and level it off for the time being.
epson is offline   Reply With Quote
Old 10-08-2010, 10:15 AM   #10
Along those lines maybe asphalt "patch" if it's not too big:
http://www.fastenal.com/web/products...ex?sku=0204263
Cheap flooring - this OK? globus999 Flooring 14 09-17-2010 08:52 AM
