Questions On How To Extend A Deck? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 06:56 PM   #1
Rewards Points: 20
Questions on how to extend a deck?
I have a deck off the back of my house that is 10x12 (10’ depth, by 12’ width). I would like to extend the deck’s width by 7’. To accomplish this, I was thinking of pouring new footers, offset by a few inches with the other footers, and sistering the new beams to the original beams. I figured the footers would have to be offset a bit, as the beams would be off by an inch or so. I would then install the additional 7’ ledger, use new joists for the new portion, etc… Is this a kosher way of doing an extension? Or am I better off installing the new footers inline with the old, taking down the complete deck, and install everything from scratch? I am not sure if tying the two decks together is kosher.
Thanks,
Snoopy_
Snoopy_ is offline   Reply With Quote
Old 06-14-2011, 07:37 PM   #2
Rewards Points: 5,336
I would isolate the two decks, but build them in proximity to one another.
I'd move the footings away from the original footing by at least 2 feet.
Ron
B. Franklin 1759
Old 06-14-2011, 10:23 PM   #3
Rewards Points: 20
re: extending deck
To be more descriptive, I am extending it in a trapezoidal way... 7.5 feet at the base, then 5 feet out from the house, then connecting to to a point at the top. So it turns out to be a small triangle extension... so I am not sure how extend it. I think I need to post a picture of what I plan for it to make sense.
Old 06-14-2011, 10:32 PM   #4
You would attach a ledger to the house and support posts where you need them. Still no need to physically connect it if you don't want to.
It depends on how the current deck's structure is set up.
Ron
B. Franklin 1759
Old 06-15-2011, 07:44 AM   #5
I think you should also consider this options to fulfill your requirement.
Petric is offline   Reply With Quote
some questions about ground level deck fabian Building & Construction 2 08-31-2010 07:24 AM
Drafting questions for deck Ontario Buckeye Building & Construction 8 05-11-2010 08:13 AM
Roof top deck questions fixeruppers Building & Construction 2 06-30-2009 05:04 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
New deck staining questions sk8z Painting 7 11-14-2007 06:45 PM
