Old 03-18-2010, 12:48 AM   #1
Questions about working with fiberglass doors?
I like hanging doors in old door frames (a pain, but I like the challenge). Can fiberglass doors be cut with a circular saw, and trimmed with a plane?
I've heard somewhere they can't be cut. If not, I will try to use some hardwood doors.
darsunt is offline   Reply With Quote
Old 03-18-2010, 07:08 AM   #2
Trying to set a new energy efficient door into an old frame is a waste of time, from an energy standpoint. Better to install with a new weatherstripped frame and threshold. It can be done by someone that is familiar with such things, but is usually more expensive in time than replacing the whole frame.
To answer the question, there are limitations to cutting fiberglass doors, which vary by manufacturer. And it depends on how much you are cutting. Most doors have wood cores or internal frames. Some have more wood than others, which makes trimming them different. If you cut past the wood frame, it needs to be reinstalled(gets complicated). Better not to try to modify them.
Old 03-20-2010, 12:47 AM   #3
The frame the door is hung in is installed inside the rough opening, correct? So you need to rip out the old hanging frame down to the rough opening?
Fiberglass Door Question rcayard7 Carpentry 6 06-08-2009 12:05 AM
Trimming Fiberglass doors sjaconski Carpentry 7 10-14-2008 01:59 PM
UGH! A lesson for new Pre-Hung Doors javan General Discussion 6 08-08-2008 08:47 PM
painting fiberglass doors rcahow Painting 2 07-11-2008 06:21 AM
Masonite pre hung doors sticking hot weather Pawl Carpentry 4 07-08-2008 05:26 PM
