Questions About Sealing Joints For Deck Repairs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2012, 09:54 PM   #1
Rewards Points: 682
Questions about sealing joints for deck repairs
I plan to replace the wood on the railing cap of our deck. Instead of the usual caulk I was thinking of using polyurethane to seal the joints. Poly is more expensive, is this idea good?
Also instead of priming and painting the ends of the wood after I cut them, I was thinking of using that clear wood preservative, because it would be faster. But would caulk stick to a wood surface that has been sealed with preservative?
darsunt is offline   Reply With Quote
Old 08-06-2012, 06:56 AM   #2
AHH, SPANS!!!
Rewards Points: 1,166
If you are using pressure treated wet lumber it will not work to well with anything sticking to it until it has a chance to dry out some over time. A good construction adhesive - Glue at the seams/joints will not hurt though..
hand drive is offline   Reply With Quote
Old 08-06-2012, 09:22 AM   #3
Rewards Points: 13,450
Many times we have been installing composit decking on top of the top rails.
It acts as a protective cover over the wood so there's no more splitting and slivers to deal with.
Constrution adhesive and screws coming up from the bottom, not the top makes for a nice clean look.
caulking shower stall questions, removal, grout sealing etc detyianni Plumbing 0 11-29-2010 09:00 AM
Questions about sealing a crawlspace. John_W HVAC 5 07-11-2010 02:24 PM
Sealing Porcelain Tile Questions eis61374 Flooring 2 03-23-2009 07:11 PM
questions on sealing slab , underlay pad, double padding under laminate pauls Flooring 8 02-21-2009 01:10 PM
sealing tile grout questions 4just1don Remodeling 5 06-27-2008 05:37 PM
