#1 |
i carved this sword
question of wall framing
i have a question on wall framing, for exterior and interior walls, and its on what is the best way to do this if i would be doing all the building myself, (please see pic)
![]() as you can see i have 2 examples, which is better? or does it matter? would the top one be allowed by code? |
#2 |
Xtreme DIY'r
No reason for the extra stud on the top
Since you need 16" OC & 8' on centers for drywall etc bottom is the best way to go Extra studs also transmit more cold from the outside So better to have insulation instead of the stud |
#3 |
i carved this sword
question of wall framing |
#4 |
Xtreme DIY'r
I also go to 2x6 exterior walls & use R19 or R21 insulation
#5 |
I have gas!
It probabaly doesn't matter but yYou may want to offset the top and bottom plate breaks.
I tear things down and build them up. |
#6 |
i carved this sword
for framing rough opening doorways, would using a 2x6 work with cripples over the header? im guessing a header would be 2x, 1/2" plywood, 2x, 1/2, 2x, would that be right?
#7 |
Xtreme DIY'r
For headers I use triple headers & rigid insulation as the "middle" piece
Basically (2) 2x headers on the outside, then rigid foam, then the 3rd 2x on the inside 2x6 = 5 1/2" (3) 2x's = (3) *1.5 + 1" rigid...or 1/2" sheathing & 1/2" rigid |
#8 |
i carved this sword
can headers and cripples be used together?
#9 |
Mod
Very simple, Pic. # 2 "IS CORRECT".
Although I wouldn't line up the top and bottom plates. Last edited by kwikfishron; 03-16-2010 at 08:17 PM. |
#10 | |
place your header to the outside and insulation to the inside so the inspector can see it.
#11 | |
Xtreme DIY'r
question of wall framingQuote:
And anything else you might nail...trim might be a problem too With 1 header on the inside you have something to screw/nail into |
#12 | |
Make the header sit 1 1/2 inch higher and infill the top with an upper 'sill' piece on the flat. Do it all the time around here for doors and windows.
#13 |
i carved this sword
#14 |
Moderator
"what is the best way to do this if i would be doing all the building myself," ------- I would use my wall jacks to raise the wall one piece. If not, either example is per code but #1 is easier and way quicker when working alone with a longer wall, pieced together. (Especially on a step ladder trying to line and nail a 12' high wall through the lower top plate, then add the upper plate, 4' minimum lap each way--- as in #2. In detail #2-- just subtract the required overhang top plate from the abutting wall, plus 1/4"- elbow room, hold the stud shy of the end at one wall- then when butting the two end studs the top plates tighten before the top ends of the studs, no toenails or forcing the joint tight). The top and bottom plate break placement are not important unless fasteners are missing, or too close to a partition or corner. The double top must now be offset from the break below it by 24", per code. Around here, the cripples are the short studs between the header and the 1st top plate, OR the short studs between the window sill and the bottom plate. As Jl said, place your header out-most with the header stamp readable from the inside (not covered by sheathing) for the inspector, later install the rigid insulation.
"For framing rough opening doorways, would using a 2x6 work with cripples over the header? im guessing a header would be 2x, 1/2" plywood, 2x, 1/2, 2x, would that be right?" ------- The header is rated for the opening as to loads it carries. Example of exterior wall: http://www.burlington.org/Building08/Spans.pdf Interior: http://ftp.resource.org/bsc.ca.gov/t...2_page0376.pdf The plywood is only a filler. Check with your local Building Department for current framing codes. Example of older codes: http://www.mcvicker.com/resguide/page011.htm Be safe, Gary
Clothes taking longer to dry?
Clean the dryer screen in HOT water if using fabric softener sheets. They leave a residue that impedes air-flow, costing you money. Clean the ducting in the last six months? 17,000 dryer fires annually! |
#15 | |
i carved this sword
| Display Modes | |
| Crown moulding: Flat ceiling to angled wall question | RP31 | Carpentry | 19 | 10-30-2012 04:18 PM |
| Framing stair knee wall... | bparise | Carpentry | 6 | 11-14-2009 01:03 AM |
| Temporary wall support question | discojv | Building & Construction | 7 | 01-25-2009 08:23 PM |
| Raising Doorway Height (load bearing?) | treefrog | Building & Construction | 6 | 02-25-2008 10:11 PM |
| Framing an angled wall | TheBrownsFan | Building & Construction | 8 | 01-14-2007 10:22 AM |
