Question Regarding Paver Stones Driveway Sub Base - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-17-2011, 10:03 PM   #1
Question regarding Paver Stones driveway sub base
Hey all. First post here!
I'm located in Tucson, AZ. Here our soil is a very hard, near concrete substance called Caliche. (http://en.wikipedia.org/wiki/Caliche) .. To give you an idea of how hard it is, it took about 2 hours with a breaking bar to put my mailbox in. My question is this: Would I still need to dig as deep and mix in gravel to do a Proper driveway with pavers, even with this incredibly hard soil?
Oh, attached is what I envisioned as the brick pattern, albeit a bit wider (10ft x 32ft driveway)
Thanks for reading.
Kyle
krwhite is offline   Reply With Quote
Old 08-17-2011, 11:37 PM   #2
Too Old
I do a 1" sand bed with no gravel bed, take your time getting the grade right. Being in the desert you don't want the caliche to have moisture unlike clay this is what I have found out. I have done quit a few driveways, walkways, and patios with 1" sand in the desert and no call backs. Make sure you get the grade right along with a good edge row.
"Yeah, it's a nice garage, but you have to keep it heated at all times so it doesn't mess up your roof line."
havalife is offline   Reply With Quote
The Following User Says Thank You to havalife For This Useful Post:
AndyGump (08-18-2011)
Old 08-18-2011, 01:58 AM   #3
Thanks! Glad to find someone with experience in the desert. Would you recommend a plate vibrator, or a simple, manual hand tamper? Are results much better with the automated approach?
One thing I notice is that some folks will tamp the 1" of sand after its leveled, relevelling, retamping, etc.. While others seem to level it out, lay the bricks, then plate vibrate the whole thing. I can see the rationale of not tamping the sand too much as vibrating it afterwards will inset the bricks into the sand better? This is an area where I'm seeing a bit of conflicting methodologies.
re: replace asphalt driveway. best method?? gramps416 Building & Construction 12 05-24-2011 11:50 AM
HELP! Paver Base problem mytjojo Landscaping & Lawn Care 0 05-03-2011 05:41 PM
Paver Base Material Hawk18 Landscaping & Lawn Care 6 05-01-2011 11:43 AM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
