Old 12-15-2009, 08:41 PM   #1
Question regarding adding a stud wall to a brick structure
We are about to begin an addition to the rear of our home. We have hired someone to do the black in and then I will take over once it is blacked in. The rear of the house is brick. The framer told me that he would just butt the stud wall up to the brick and attach it with silicone and some masonry bolts. He told me that he would fur out the existing brick walls in order to hand sheet rock. Is this normal or should the brick walls be removed? What about moisture between the existing brick wall and the new sheetrock wall? If the brick wall remains, what type of insulation should I apply that would be safe to rest against the brick?
Thanks for any advice
jcieutat is offline   Reply With Quote
Exterior Brick Wall with No Sheathing? beesan Building & Construction 1 12-08-2009 06:57 AM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 07:41 AM
Interior Wall Stud Joist Connection Issues. Brandnewruins Carpentry 5 04-23-2009 12:46 AM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
New opening in a brick veneer wall - installing new brick ties? GrantJohnson Building & Construction 3 01-28-2009 11:17 AM
