#1 |
Question on Monolithic slab - Pour all at once?
The contractor quoted to pour all at once - the 15" X 24" footing, 3 feet retaining wall on two sides and the 20 X 32 feet slab. Is this feasible? Quotes received from other contractors split this into three days – one day each to pour the footings, wait for some time, and than pour the retaining wall, back fill, compact and finally pour the slab on a separate day.
Is this acceptable practice? Pouring all (footing, retaining wall and slab) in one pump?. I am concerned that it might develop cracks since this would be a one huge piece of structure. Also I thought that the better idea is to pour the footing first and let it get cured and than pour the rest since they all sit on top of footing. Now the guy who quoted monolithic slab is the lowest quote, also have excellent reputation, so I would like to know if this is a correct way. Please enlighten me on this. Thanks Last edited by seth; 05-04-2009 at 02:11 PM. |
#2 | |
Old School
Question on Monolithic slab - Pour all at once?Quote:
And here is the reason: You suggested you have at least part of three feet of fill within the perimeter of those walls that will require some compacting. If, indeed, you anticipate filling all of that three feet, the fill needs to be compacted in progressively prepared layers. ie. fill eight inches... compact it all... add eight more inches... compact it all again... add eight more inches.... do the total compacting thing again. And on and on till you fill the required depth. This cannot be accomplished without the stem walls first being in place to backfill your fill dirt against. If, on the other hand, the intention is to simply dig down for the footers, you still have to compact the relatively small area of fill all around the backside of the form that would be used for the inside of the stem walls. And you couldn't get the form boards out... Not good construction practice to leave form boards in the ground. Remember, even pockets and edges left uncompacted are not good, and are subject to excessive settling and eventual cracking. A monolithic slab, one poured with slab and "haunch" footing done all at the same time is fine...... IF done upon undisturbed or thoroughly compacted soil. No way this is going to happen with three foot walls.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T |
#3 |
Thanks Wille. Yes you are right; right now all the three foot of the wall is below the slab grade. So It needs to be filled completely with dirt/57 gravel and compacted.
Can I pour the retaining wall and the footing in one pump and the slab separately? |
#4 | |
Old School
The most economical, and at the same time, effective way is to dig and pour the footing first. And as really SHOULD be done with all poured concrete (but rarely is anymore) after a 28 day wait, go ahead and either lay up block stem walls, or form stem walls and pour them. The full 28 day wait is not necessary after pouring the stem walls before you pour the slab. But the walls should have at least 10 to 14 days to develop enough strength to help resist the lateral forces which will be applied from the compacting process. In reality, it should go like this:
BTW, Your slab should be kept cool with water during this curing time. (Curing concrete creates immense internal heat that hurts the strength-developing process if left unchecked.) Often hay or burlap sacks are spread on the concrete to retain the moisture from occasional (every few hours) sprinkling. Concrete should never be allowed to dry out during the curing cycle. As crazy as it sounds, wetting concrete, and letting the water evaporate can also cause cracking. Once you begin wetting it down, keep it wet for the whole curing cycle. Doesn't hurt to hold the moisture in with plastic sheets. Is all this wet curing a little bit of a hassle? Yes, but it pays off in the long run. This is one of those "Do the job right, and it will last." things. Of course it goes without saying that concrete should be poured as much on the dry side as is practical. Many contractors soup it up to facilitate faster and easier placement. This is hurting you. Don't let them do it. Soupy concrete has way more potential for cracking than dryer stuff.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 05-04-2009 at 06:10 PM. |
#5 |
Thank you again for your help; No Currently I do not have a retaining wall. I need to pour the footing, retaining wall and the slab
#6 |
Old School
I was quite serious about the likelihood of the retaining walls (stem walls) being pushed outward from compacting forces. I've seen it many times, and even lost a wall once, myself, before I wised up and began doing it right.
Leave your concrete pour low by about 2/3 of the header blocks (about an inch to an inch and a half of empty space for the slab pour to lock [key] into). It will create a better lateral lock all around the perimeter. The bottom drawing shows somewhat how it would look with a slab poured.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 05-05-2009 at 11:31 AM. |
#7 |
Hi Wille
Could you please explain the second para. When you say Header, what exactly you mean? Also when you say Leave your concrete pour low you mean the slab? |
#8 | |
Old School
The header row is the final top row. The one with part of the side of the block cut out so you can pour your slab right up to the outside edge.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 05-05-2009 at 10:51 AM. |
#9 |
Thanks again
I am not planing the retaining wall as a block wall. Don;t want to use precast blocks. I am asking the contractor to POUR the retaining wall which will be 3 foot tall at one side and gradually tapers down to a foot |
#10 |
WillieT: if the slab was at the bottom of the stem wall, is it OK to pour the footing and slab in one pour and then build the block stem wall? Or should the footer be poured, then stem wall, then slab?
#11 | |
Old School
It generally isn't done. I can't give you an engineering explanation of why, but the basement slab is usually poured as a free-floating separate component after the footer is poured, and the walls built. Perhaps someone with a better engineering background than I have could tell you why...... and maybe there's really no reason? Could be one of those "We've always done it that way." things. Truthfully, we don't do a heck of a lot of basements here in Florida, so I really am not that well acquainted with the whys and wherefores of basements. The few we do are just done as the drawings call for them.
"True eloquence consists in saying all that is necessary, and only that which is." François Duc de La Rochefoucauld Willie T Last edited by Willie T; 05-05-2009 at 11:44 AM. |
#12 |
Old School
Then you don't even have to be concerned with things like header blocks.
#13 |
Willie T, (speaking of we've always done it that way) I have never poured the footings and then the walls, we always did a monolithic pour when it came to the footings and walls. In my opinion a monolithic pour is just easier, well because, we just have always done it that way. However, never did a footing, wall and slab at the same time, except for a few small freestanding garages. I will have to agree about waiting a few weeks to backfill, compact and then the slab.
#14 | |
Old School
But here in FL, we almost never dig down more than a couple of feet for house footings, and formed stem walls are a rarity. It would be an expensive hassle for us to form and pour a combination footer and stem wall for residential work. Our houses only sell for about half of what they do up north, but materials seem to cost as much or more, so it would be financial suicide for the average builder to go to such unnecessary extremes on a foundation.
#15 | |
| Display Modes | |
| See Picture - To what Level pour slab? | seth | Building & Construction | 4 | 04-27-2009 08:06 AM |
| question on suitability of monolithic slab | rtoni | Building & Construction | 5 | 03-31-2009 06:18 PM |
| Monolithic or floating slab ? | pushkins | Building & Construction | 2 | 02-26-2008 11:09 PM |
| Bathroom subfloor on concrete slab question | Mikedks | Flooring | 2 | 02-20-2008 08:28 PM |
| Concrete slab question | houdinihar | Building & Construction | 2 | 06-07-2006 09:04 AM |
