Question On IRC Table R803.5.1(9) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-30-2012, 09:22 PM   #1
cortell's Avatar
Rewards Points: 504
question on IRC Table R803.5.1(9)
This IRC table is named Rafter/Ceiling Joist Heel Joint Connections. Anyone know exactly what that's trying to prescribe? I thought I knew until I saw the table cell that says 39 fasteners are needed at the rafter-joist connection of a 3:12 roof (with 70psf ground snow load and a 36' roof span). Seriously? 39 16d common nails at a joint? Considering a nail should be no closer than half its length to another nail, is 39 nails even possible???). I'm assuming I'm just not understanding the table correctly.
cortell is offline   Reply With Quote
Old 03-31-2012, 12:37 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 674
Send a message via Skype™ to AndyGump
Oh, I suppose you could say that it is excessive but, the drawing shows 3/12 pitch with Roof Rafter @ 2 x 10 and Ceiling Joists @ 2 x 10.
So the low intersection between the two should allow for that many nails.
You know they are calling out for a rafter span of 36' (feet) right?
Andy.
P.S. it is section 802.5.1 not 803.
Residential Drafter/Designer
www.draftinginoc.com
AndyGump is offline   Reply With Quote
Old 03-31-2012, 08:38 AM   #3
cortell's Avatar
Rewards Points: 504
Nice! You made a believer out of me. In fact, you inspired me to fire up my CAD program. I calculated the potential for a whopping 75 nails, spaced 3/4" from the edge, and 1-1/2" from each other, in that triangular area. So indeed it is possible. Thanks! BTW, the table number I referenced is in the 2006 IRC. My bad for not mentioning the year.
Old 03-31-2012, 11:51 AM   #4
Structural Engineer
Thirty nine nails might sound like a lot of nails if not taken in the context of the shallow roof slope and the heavy live load.
The shallower the rood slope, the larger the horizontal thrust there is to be resisted by the ceiling joists through that nailed connection.
A 70 psf live load is a large live load. A 70 psf live load is about the same live load required for automobile parking decks in some locations.
House Engineer is offline   Reply With Quote
The Following 2 Users Say Thank You to House Engineer For This Useful Post:
AndyGump (03-31-2012), cortell (03-31-2012)
Standard or Sliding Mitre Saw? Or table saw? 7.62 Tools 18 05-07-2012 08:53 AM
How difficult to build this coffee table? Ammi Carpentry 12 09-21-2011 10:45 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
hrv question indep HVAC 3 07-17-2008 10:39 PM
Craftsman Table Saw Question TonyCooper Tools 2 12-01-2006 08:44 AM
