Old 04-03-2010, 07:53 PM   #1
Question
Question on Horse hair plaster
Just closed on an investment property and the house is 100 yrs old. It is all horse hair plaster and is covered in at least 4 layers of wall paper. Is it possible to just sheet rock over the horse hair plaster or do we need to tear it down?
anasotoandrews is offline   Reply With Quote
Old 04-03-2010, 08:39 PM   #2
remodeling pro
Is it physically possible;yes if you use long enough screws to reach the studs. But it also brings up a few other problems:
Adding a layer of drywall will deminish the depth of the trim it butts to considerably, so the trim will be very thin looking on the drywall.
It requires a judicious drywall team, as they have to cut around any trim profiles in play, and the finisher will require extra effort to cleanly float to all the trim.
Electrical boxes which may have been added in the plaster field will require extension rings added to them, so the devices in them will be seated on something more solid than the edge of a drywall cut out.
troubleseeker is offline   Reply With Quote
Old 04-03-2010, 09:26 PM   #3
Remodeling Contractor
the other issues is you do not know what is behind the walls. old houses are very leaky and energy hogs. It will be worth the effort to do it right and remove all interior wall covering, air seal and insulate correctly and then drywall. This way the studs can be shimmed to give nice straight walls.
Old 04-03-2010, 10:50 PM   #4
remodeling pro
That is definately the "cadillac" plan $$. (better watch out for the Obama tax). You also usually lose some trim through breakage when removing; and when reinstalling, the door and window trim usually has to be built out on the back, because the new drywall is not as thick as the old plaster coats, so the jambs are to wide.
And shimming the old style rough cut studs straight has always been a real can of worms in my experience. The did not worry so much about identical stud dimensions because they set the plaster grounds straight, and then screeded the plaster to them, resulting in a flat wall surface.
Old 04-03-2010, 11:27 PM   #5
you never go wrong doing it right. patching will cost must more in the long run
Old 04-04-2010, 12:28 AM   #6
Moderator
Another thought is the wallpaper may have a vinyl layer, a vapor barrier. Depending on your location, this could be a problem.
Be safe, Gary
Clothes taking longer to dry?
Old 04-04-2010, 04:55 AM   #7
paper hanger and painter
chrisn's Avatar
Why in the world would you remove the plaster in the first place?Remove the wall paper, prime and paint or re paper and you're done!
Old 04-04-2010, 07:46 AM   #8
we did this on our 1856 home - stripp'd down to the studs - found lots of old newspaper ( vapor barrier ? ) but no insulation, of course the sheetrockers were happier & the home was much warmer w/no more drafty winter winds
now go find lots of eggs
itsreallyconc is offline   Reply With Quote
Old 04-04-2010, 08:44 AM   #9
and you get a chance to fix the electric or plumbing that is long past it's life expectancy.
Old 04-04-2010, 10:49 AM   #10
Xtreme DIY'r
I have one room where they added 3/8" over the old plaster/rock system
I can't stand it & will be gutting the room & redoing it
Do it right the 1st time
Smoothing Joints Between Sheetrock and Plaster Without Sanding OldManMike Building & Construction 6 06-30-2009 08:42 PM
Right materials to patch plaster on masonry? jimhome Remodeling 3 06-08-2009 12:23 PM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 09:19 AM
Old Concrete Board with horse hair w/asbestos scott13676 General Discussion 4 03-04-2008 05:13 PM
