Question With Hole In My Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 01:13 PM   #1
question with hole in my wall
I'm planning to repair this hole in my wall, with adhesive fiberglass tape.
Can i use something like [COLOR=blue ! important][COLOR=blue ! important]Durham's[/COLOR][/COLOR] rock hard water putty? On the can it says that its good for repairing cracks and stuff, tiles, wood, etc...but im not that sure.
BTW, when it says " Mix 3 parts powder and 1 part water" would that be like mixing 3 cups of the powder and 1 cup of water?
http://www.waterputty.com/repair.htm
klonerx is offline   Reply With Quote
Old 01-20-2008, 04:31 PM   #2
Rewards Points: 1,442
Yes, 3 cups powder and 1 cup water. Or 3 tablespoons powder and 1 tablespoon water, depending on how much putty you need.
I would say no problem, except in most cases hard water putty is overkill for an ordinary dry location patch job. More expensive, like.
Check the instructions for what kinds of tools should be used. "Rock hard" putty that is meant to be stuffed somewhere and left as-is may be difficult to file and sand in an exposed location after it hardens.
Old 01-20-2008, 04:53 PM   #3
Eibwen
Unless the hole is in a unique situation. I would use drywall mud.. .
Stop and think about the next step... ROCK HARD....
How you gonna sand/feather it if its rock hard???
Sammy is offline   Reply With Quote
Old 01-20-2008, 05:15 PM   #4
well it does say that i can be sanded 8 hours later on my can..and I have 2 drums full of the stuff, i don't want to waste it and buy some the mud filling type. Do you think i can use to it patch up a 4x4[estimate] hole?
Thx too all
Old 01-20-2008, 06:06 PM   #5
Master General ReEngineer
Bondo's Avatar
Rewards Points: 608
Ayuh,...... Why Not..........
Just because it isn't the 1st Choice,....
Doesn't necessarily make it a Bad Choice.......
Go for it..... It'll be plenty Strong......
Old 01-20-2008, 08:10 PM   #6
ok, thanks everyone. Ill get to it as soon aspossible...
Basement knee wall question vugger Building & Construction 2 01-05-2008 10:02 PM
Garage wall construction question Bjonas Building & Construction 4 01-01-2008 05:18 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
knee wall question jscholl411 Building & Construction 7 10-10-2007 01:30 PM
Hole in wall w/ stress cracks... lots of detailed pics (NOT 56k connection friendly) Thaipo Building & Construction 8 05-21-2007 07:40 AM
