Question: Fiber Cement Shingle Siding Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-06-2011, 07:46 PM   #1
I am in the process of installing fiber cement shingles (Certainteed) on my house and I'm uncertain as to how to install the 2" starter strip where the dormer intersects with the roof (see attached photo.) The instructions appear to indicate that the starter strip is installed parallel to the roof line but it seems to me, that would create an awkward angle in areas where the top of the shingle panels make contact with the starter strip. If the starter strip is installed horizontally like the shingles - will I need to do a bunch of short starter strip pieces only in those areas where the bottom of the shingle panel makes contact with the start strip? Thanks in advance for your help.
Greg~
Question: Fiber Cement Shingle Siding Installation-house-002.jpg
Greg D is offline   Reply With Quote
Old 09-06-2011, 08:15 PM   #2
kwikfishron's Avatar
Rewards Points: 92
You should only need the starter on the first little piece of siding.
Make sure to lay a board on the roof and side tight to that board so you’ll end up with a nice straight line over the roof.
kwikfishron is online now   Reply With Quote
Old 09-06-2011, 09:41 PM   #3
Thanks Kwikfishron. I was planning on using a 5/4 board on the roof so I would have a 1" gap between the bottom of the siding and the jumbo wood shake roof - what are your thoughts on that? Certainteed recommends a 1 1/2" clearance but if I did that with the jumbo shake roof - which I hope to replace with a composite in the next five years or so, I'm guessing it would leave an approximately 2 1/2" gap, which would be a bit unsightly. This is not an area of the roof that would get alot of stand snow so it's not likely to have alot of moisture contacting the bottom of the shingles. Anyway, I appreciate your insight and input.
Greg~
Fiber cement board Skibob Carpentry 3 06-18-2011 08:20 PM
PVC cement question - the glue doesn't seem to work whiskers General DIY Discussions 3 05-20-2011 12:27 PM
cement fiber siding lancen Building & Construction 7 07-02-2010 07:48 PM
Vinyl meets Cement (Hardie) Siding at corners WaldenL Remodeling 3 06-15-2010 07:18 PM
"Maintenance Free" Siding Materials (Vinyl, Steel, Fiber Cement) diggitydog Building & Construction 12 01-23-2009 05:24 PM
