Question: Bedroom Door Code? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-04-2009, 04:09 PM   #1
Question
I found a beautiful door that I would like to use for my 2 bedroom doors! It is not a typical size, 84Hx28W. Is there building code that states your Bedroom doors have to be a certain size? I am located in Chicago if that matters
nik2009 is offline   Reply With Quote
Old 05-04-2009, 04:59 PM   #2
Rewards Points: 5,336
Typical bedroom doors are 30" wide. I think more for getting in the furniture then egress.
Unless you're really, really fat, you should be okay with 28".
Ron
Old 05-04-2009, 09:43 PM   #3
Nia
You can always call the building dept for your area. In Houston you can use 28" size door for your bedroom.
Nia is offline   Reply With Quote
Old 05-05-2009, 07:04 AM   #4
Rewards Points: 346
Call your local building department. Many communities have size requirements for doors. I know of one that requires bathrooms on the first floor to have a 36" door. All that said if all you are doing is replacing an existing 28" door I would just do it.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-05-2009, 08:03 AM   #5
Registered User
Termite's Avatar
I can say that the International Residential Code does not have a minimum door width for bedrooms or any other room in the house. The only door that must be a minimum size is the main exit door, which must be 3-0. As stated, it is always best to check local codes to make sure they didn't amend the building code.
Dark Blue Bedroom Question cdcamaro9534 Interior Decorating 4 01-18-2009 02:30 PM
Painting my bedroom r3dmonk3y Painting 3 12-30-2008 11:58 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
your guestimation and or opinion on removing a bedroom shan Remodeling 2 12-09-2005 03:46 PM
