Question On Addition - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-16-2010, 10:57 PM   #1
Rewards Points: 28
Question
Question on addition
this is so interesting...i had a contractor knock off my old back porch, 6 x 16 and add a 4 season room, 14 x 16...unfortunately i started just as i got laid off...but still did it right, the best i could and matched my 1940s house exactly, inside and out...nice hardwood floor (factory finished) to match house, they matched all the trim perfectly...i was on their butt ha...i put in double pained windows with all the extras, even tempered glass...lots of windows!....7 windows and a french door...so anyways...i LOVE my room (there is an very old outdated badly designed kitchen this leads off from that i was going to do at the same time, but that will wait til i am working)..but my question is he also built this on piers...it is 16 feet along the house, 14 back. he attached it to the main beam of the house..he was going to use piers along the house but said that would be better...and he used 8 piers..4 piers along the middle of the room horizontal to the house and 4 more on the outside wall. i had 2 corners slit just a tiny bit, enough to break the paint and thats all...this was done last december. so do you think he used enough piers? he is a good contractor and also a cement guy. one more question please. he used rigid blue insulation under the room, a lot of the soft insulation above that, then a high grade subfloor...then a lanai floor, then the hardwood. my question is there is nothing under the rigid floor if i go under the room...he wrapped the room and did a fake cement foundation, i made him put a door..so i can get under there...but it seems to me there should be something under the rigid insulation..is it ok to not have anything? he said he could put plywood under it if i wanted...i was even thinking plastic sheets....what is the right thing to do? is it supposed to breath?? thx much. my first post to this neat group.
alanj is offline   Reply With Quote
Old 09-16-2010, 11:15 PM   #2
Registered User
Rewards Points: 526
Welcome to the forum, both of you!
Leaving the concrete patio---- that probably doesn't have a vapor barrier, gravel or steel under it per Code that may be required for a heated space, ask your Inspector: pp.3- fig. 5: http://www.codecheck.com/cc/images/CC5thEdSample.pdf
Gary
Old 09-17-2010, 06:14 AM   #3
Rewards Points: 5,336
This structure should have been engineered by an architect. The plans should have been approved and the structure inspected as it was built.
All these questions would have been addressed before the addition was started.
Is this the process you went through?
Ron
Old 09-17-2010, 02:03 PM   #4
Rewards Points: 28
Hi Ron. No. I went to my county for a permit and they said since i was redoing an existing structure that i was grandfathered and did not need a permit. And, no the plans were roughly drawn out by my contractor...with changes as we went along. This is a good man, he does real quality work in town.
thanks.
Old 09-17-2010, 04:26 PM   #5
thanks.
If you knock off a porch and rebuild a structure, you need to have it engineered. A contractors ability to build a structure doesn't mean he's qualified to plan the structure.
If you want answers to your questions, hire someone qualified to do an onsite inspection.
Ron
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 01:30 PM
Half-story Addition uncleslam Remodeling 6 06-21-2008 04:17 PM
Basement vapor barrier question rob7young Remodeling 2 04-13-2008 09:10 AM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 07:57 PM
Home Addition cost? Russ Chewning Building & Construction 3 10-23-2006 07:59 PM
