Question Aboutinsulating A Homes Ext Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-09-2009, 04:13 PM   #1
Question aboutinsulating a homes ext walls
I was wondering if someone could offer some advice on insulating exterior walls of a home. The home is a slab and has no insulation between the studs. I thought I had seen a technique where a hold is cut near the top of each stud cavity and insulation is pushed thru the hold into the space between the studs. Is the machine for that something that could be rented? Can someone tell me what it's called or share some other advice?
thanks
brokenhammer is offline   Reply With Quote
Old 12-09-2009, 06:48 PM   #2
ccarlisle's Avatar
thanks
Depends what part of the globe you live in.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-09-2009, 09:52 PM   #3
Stick built. The home is in the midwest.
Old 12-09-2009, 10:29 PM   #4
Registered User
Rewards Points: 5,514
http://www.google.com/imgres?imgurl=...ed=0CAoQ9QEwAA
http://www.karg.com/pdf/Insulaton_de...and_Biddle.pdf
Be safe, Gary
Old 12-10-2009, 06:24 AM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
The short answer is, yes, you can blow cellulose insulation in through holes at the tops of the walls. You can rent the machine to do it. Some of the box stores like Lowes or Home Depot will loan the machine, if you buy the materials from them.
Old 12-10-2009, 07:17 AM   #6
DIYguy2000's Avatar
Rewards Points: 93
Just looked into renting the machine myself at Home Depot. Rental is $45 per day (Canada). Still have to find a price and volume required for the bags of insulation though.
I see lowes sells 16 cu.ft bags for $11.57 (US), so that's roughly one bag per 1.5' of 8' high 2x4 stud wall. Seems pricey.. maybe it comes cheaper? someone correct me if that's the case.
I've read that cellulose insulation has a R value of about 3.5 per inch.
DIYguy2000 is offline   Reply With Quote
building shower walls with concrete canyongirl Building & Construction 13 03-14-2010 12:44 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 08:17 AM
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 04:58 PM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 02:43 PM
