Question About Windows, Siding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2011, 06:25 AM   #1
Rewards Points: 93
question about windows, siding
I have an older house that I put new construction windows in because the old ones were in really bad shape. The house has the original wood siding and then a previous owner put vinyl siding over that. All the windows are in and I am now going to put the vinyl back on.
Can you just run the vinyl up to the wndows without any trim? I was going to put trim but now I am not sure in down the road I am going to do a full re-side with cement board and that may change window trim design.
What do you think?
bfan781 is offline   Reply With Quote
Old 06-20-2011, 06:48 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
you can do thatjust make sure you put a dripcap on and hopefully you flashed the sills good
Tom Struble is offline   Reply With Quote
Old 06-20-2011, 07:25 AM   #3
kwikfishron's Avatar
Rewards Points: 618
What, no J?
kwikfishron is offline   Reply With Quote
Old 06-20-2011, 07:43 PM   #4
Originally Posted by kwikfishron View Post
What, no J?
i guess if he wants it
Old 06-21-2011, 02:44 PM   #5
Rewards Points: 93
Yes, I j channeled the windows.
What do you guys do around decks and bulkheads? Do you run a starter strip or can you use a j channel there too?
Old 06-22-2011, 09:32 PM   #6
Registered User
Rewards Points: 5,520
http://www.vinylsiding.org/installation/manual/
http://www.abtco.com/kp_abtco/docs/A...tructions_.pdf
Gary
New windows and new vinyl siding Fisher252 Building & Construction 11 05-08-2011 11:17 PM
Installing full frame windows with existing metal siding testerdiyc Windows and Doors 4 03-18-2011 08:38 PM
New windows & siding? cbzdel Remodeling 2 07-21-2010 03:55 PM
How do I efficiently shop windows and siding??? dignan99 Building & Construction 13 06-02-2009 10:40 PM
Replacing windows and siding ramiree Remodeling 3 07-03-2008 11:44 PM
