Question About Sump Pump - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-13-2011, 10:29 AM   #1
Question about sump pump
Obviously, I need access to the sump pump, but it happens to be in prime real estate to place a screen for a home theatre setup. The problem lies in where it is situated. It is placed in a corner with a window almost directly above. If I was to do the typical full "closet" enclosure it would look horrible for the aesthetics and partially obscure the window. So now to the point. Is there a minimum size requirement for "direct access" to a sump pump? Would a smaller size enclosure work just as well and still meet code, ie something with shelf space above it? I'll have to post a picture or two, but below is a general idea of where it is situated.
The window is more offset than directly above the sump pump to the point it would overlap a wall by 3-4inches. The "i's" are where the window is. O is sump pump and periods are floor space.
______________________
|.............................. Oi
|............................... I
Thanks so much for your input!
Chris
cscpianoman is offline   Reply With Quote
Old 10-14-2011, 04:57 AM   #2
Rewards Points: 4,748
there are hard cover sumps avail w/covers that bolt onto the sump/crock - we get ours from ferguson supply,,, many of our clients can then carpet over the sump.,,, to my knowledge, there is no code rqmt re crock size OR pump capacity - best
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Sump pump float height dac122 Plumbing 8 12-08-2010 08:47 AM
well pump electrical multimeter question tpolk Electrical 21 04-28-2010 10:37 PM
sump pump question moisheh Plumbing 1 09-13-2009 02:14 PM
