Question About Stair Tread Height - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-10-2014, 01:23 PM   #1
Question about stair tread height
I am ripping out the carpet on my stairs and replacing it with wood. I am tearing out the existing 3/4 " plywood treads and replacing it with 3/4 inch Pine treads that we are staining. So far, it looks good and seems solid, but I have a question about a landing we have halfway up the stairs.
I want to put hardwood on the landing also, but I can't quite figure it out. It also has 3/4" plywood down under the carpet, but if I put the hardwood down on top if it, wouldn't that make the top step 3/4" too high? Surely I don't pull out the 3/4" plywood before putting down the hardwood planks. Is it within code to have one step 3/4" taller than the others?
Any suggestions on what I am supposed to do from here?
Thanks in advance.
bkanneg is offline   Reply With Quote
Old 03-10-2014, 01:36 PM   #2
joed's Avatar
Rewards Points: 4,022
It will make the landing step 3/4" too high from below and the next step going up will be 3/4" too low.
That is not within code.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-10-2014, 01:40 PM   #3
That's what I thought. Any suggestions on what to do now?
Old 03-10-2014, 01:46 PM   #4
Rewards Points: 1,290
And 3/4 is to thin for a tread.
They needed to be a full 1" thick. Yes it makes a big difference.
Old 03-10-2014, 01:52 PM   #5
That's my bad...I just assumed they were 3/4. I just measured and they are 1" thick treads.
Old 03-10-2014, 02:15 PM   #6
you should of left the plywood there and put these on instead
JustinK is offline   Reply With Quote
Old 03-10-2014, 02:19 PM   #7
You could cut or plane down the floor joists but you will run into the same problem at the top of the steps too unless you are leaving the carpet.
Old 03-10-2014, 08:47 PM   #8
Stairguy
Does the stair turn at a landing and then continue back up?
Millertyme is offline   Reply With Quote
Old 03-11-2014, 10:36 AM   #9
Master General ReEngineer
Bondo's Avatar
Rewards Points: 2,556
Thanks in advance.
Ayuh,.... Not that it really matters,...'But,...
Pine is Not hardwood in any way shape or form,....
Bondo is online now   Reply With Quote
Old 03-13-2014, 11:12 PM   #10
Rewards Points: 997
Suppose to be...
When the landing and stringers where installed, the tread thickness was accounted for.
ron45 is online now   Reply With Quote
Stair tread and skirt board retrofit...... Mills314 Carpentry 9 01-07-2014 07:25 PM
Newbie Seeking Advice on Stair Tread Installation Jesse84 Carpentry 11 12-12-2013 11:03 AM
Replacing stair tread on closed stringer stairs... J187 Carpentry 9 06-27-2013 07:10 PM
Stair Riser question CharlieR Flooring 1 02-24-2013 02:09 PM
Drywall bottom of stair stringers question hewey24 Drywall & Plaster 2 11-10-2010 05:24 PM
