Question About Putting Up Drywall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-24-2010, 10:31 PM   #1
Question about putting up drywall
I'm a newbie to drywall. Am putting up all new drywall in my master bathroom. I got one of the drywall books at home depot and it helped a lot.
But while hanging the ceiling drywall, I ran into a problem where one section of the ceiling drywall I put up ran about 3/4" short of the side of the wall for a length of about 12-14". Should I feel the need to replace that entire section (it was a pain, with lots of custom holes).
Or can I feel safe by just filling it in and taping it, since it's the corner where the wall & ceiling meet? If I should fill it in, what is something good to use? The opposite side is the open attic.
CZ DIY is offline   Reply With Quote
Old 02-25-2010, 05:48 AM   #2
If you were paying drywall hangers for this job, would you approve??? Do it right.
Old 02-25-2010, 06:45 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
If you mud it in and tape it, you'll probably be dealing with a hairline crack there forever. ceiling sheets should run over top of the wall sheets for support. As stated above, take it out and do it right, otherwise, everytime you walk into the room, it will be like a big sign saying "you screwed this up".
Old 02-25-2010, 06:53 AM   #4
if you can get a backer on attic side durabond gap then mud and tape as usual. if you cant get a backer work some durabond into space til flush with sheet. would you pull a whole sheet down to repair a hole in a remodel? no
The older I get the better I was
Old 02-25-2010, 07:20 AM   #5
Thanks guys, good points made on both sides of the argument.
Old 02-25-2010, 09:41 AM   #6
Drywall contractor
Rewards Points: 1,070
If it's just a foot or so of the board that's not behind the sheet on the wall, I wouldn't tear the whole thing out...
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Putting up a drywall ceiling...will need to drill into concrete. netvivi Remodeling 7 02-14-2010 06:13 PM
Bathroom drywall question... StevePax Remodeling 9 01-08-2010 02:30 PM
question about joist hangers with drywall redss Drywall & Plaster 4 10-15-2009 02:01 PM
Log home drywall question mikew Remodeling 8 09-14-2007 09:17 PM
Easy Drywall Question hohandy Building & Construction 10 12-16-2005 12:18 AM
