Question About OSB - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-10-2012, 11:33 AM   #1
Question About OSB
Hello! As I begin my first structural project (shed) this will also be my first time using OSB. I've noticed on OSB that it has a shiny side and a dull side. Which side goes out and which side faces the inside of the building? Sorry for the lame newbie question but thank you for your help!
-Seth
dezandseth is offline   Reply With Quote
Old 11-10-2012, 12:28 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 2,128
Rough side (with the lines) out.
Make sure you get it coverd quick....I does not like to be kept wet for a long time....edges will swell.
Also....make sure the bottom edge is at lest 4" above earth ground....2" above concrete.
Any wood touching concrete should be pressure treated.....and make sure you use galv nails nailing anything into the PT wood.
Old 11-10-2012, 12:30 PM   #3
kwikfishron's Avatar
Rewards Points: 1,008
The rough side goes out. That side also has lines on it that should correspond with the stud layout for nailing.
kwikfishron is offline   Reply With Quote
Old 11-10-2012, 12:33 PM   #4
Too Short? Cut it Again!
Since this is a shed, I would put a coat of simple sealer on the inside surface too. As mentioned, make sure you get something to protect the exterior on as soon as possible. OSB does not like water and moisture.
And as mentioned, keep it off the ground.
Old 11-10-2012, 03:55 PM   #5
Excellent, thank you!
Old 11-10-2012, 04:00 PM   #6
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,338
textured side goes out for saftey reasons.. when framing walls on the ground it gives traction so you dont slip. same goes for roofs, only advise though dont buy the osb from home depot for a roof... its nowhere near as grippy as weyerhauser osb
woodworkbykirk is offline   Reply With Quote
Old 11-10-2012, 09:01 PM   #7
Registered User
Rewards Points: 526
The shiny side is waxed during manufacturing to keep it from sticking to the press. http://www.apawood.org/pablog/index....Which-side-out
Remember to gap it (printed on each sheet); http://www.apawood.org/pablog/index....panel-buckling
Recommend 8" above grade; http://osbguide.tecotested.com/pdfs/en/el812.pdf
OSB won't take moisture; http://www.mastercodeprofessional.co...vs_Plywood.pdf
If you skip the WRB, or; "how to fix it later": http://www.ewpa.com/Archive/2006/aug/Paper_266.pdf
Use Tyvek rather than Typar to dry 3 times quicker when it does get wet; Fig.15; http://repository.tamu.edu/bitstream...pdf?sequence=4
Not if you live on the Gulf Coast; http://www.coastalcontractor.net/cgi...ticle.pl?id=14
Gary
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
A question about water preassure. reasonforseason Plumbing 5 04-14-2009 04:36 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
