Question About Joists And Ledger - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2010, 10:02 PM   #1
question about joists and ledger
my house is 3 years old. i was running some cable in the basement the other day and i noticed a small gap (1/8"-1/4") between my 2x4 ledger strip and my floor joists. some friends suggested i buy some shims and place them in the gap to shore up the support for my floor joists. my question is....should the shims be tapped snuggly/firmly into place so the shims will not move or insert the shims so they are not loose per se, but not quite as snug. seems to me since there is so much weight from teh joist/house that i should insert them so they are nice and tight. the 2 x4 ledger board was nailed with a nail gun under each joist with 3 nails. i hope this makes sense...thanks
mikeluvs2build is offline   Reply With Quote
Old 02-12-2010, 10:36 PM   #2
jlhaslip's Avatar
Rewards Points: 1,402
yes, it makes sense.
chances are that 'bought' shims would be cedar and are too soft for this application.
consider cutting your own shims from Fir or Oak or another suitable wood.
if you cut them tapered, use 2 shims. one from each side so the bearing point stays flat.
use full 1 1/2 inch material to match the original bearing surface area.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 02-13-2010, 08:17 AM   #3
follow up question to your reply abt shims under joist
when i out them under teh joist from each side like you suggest do i push the shims together until i can no longer push them together firmly or just push them under the joist until there is just a little resistance?
Old 02-13-2010, 12:49 PM   #4
jlhaslip's Avatar
a little tap with a hammer will do it. just snug them up.
a drop of glue won't hurt either. I assume space would limit nailing, but if you have a brad gun, pop one in there to hold the shims.
Old 02-13-2010, 01:43 PM   #5
Pro Framer
Are you sure this is the ledger that holds up your floor joist? sounds more like the plate for your basement furring wall. Do your joist fun out to the edge of the foundation? A 2x4 ledger would not hold a floor system is why im asking. If it is not the bearing point for the floor system that gap is there so that the floor does not bear on the basement floor shimming it would be bad news as you would be shifting bearing point to your slab. Can you take a pic?
Say What is offline   Reply With Quote
garage loft; ledger to ledger joists? nsixbdg Building & Construction 10 12-26-2011 06:29 PM
Connecting Ledger Board to Vertical Stud Alzipski Building & Construction 3 11-04-2009 02:53 PM
Question about Supporting My Deck. . . bochamps Building & Construction 12 05-30-2009 07:57 PM
attaching joists to ledger for pergola question soupdizzle Building & Construction 1 07-02-2008 10:32 PM
Deck Building Question - Installing Ledger Board to Rim Joists Ler0y Jenkins General DIY Discussions 20 05-18-2008 11:05 AM
