Question About Dropping Ceiling - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-02-2010, 09:54 PM   #1
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Question about dropping ceiling
I currently have 10' ceilings in both bathrooms I am remodeling. Can I frame in a new ceiling 6" or so lower without removing the old ceiling and drywall? Both ceilings have blown in insulation sitting on top of them and it would save me massive amounts of time to not disturb this. I also need to run drain vents that WERE NOT DONE by the previous owner/contractor. The new ceiling would not be insulated.
Plan: rent laser level mark out new height, frame, install lights and fans, drywall, and so on.
--Chris the DIY Guy
Working on "The Great Wall of Retaining..."
ChrisDIY is offline   Reply With Quote
Old 12-02-2010, 10:23 PM   #2
joed's Avatar
Rewards Points: 12,442
That will work.
Old 12-02-2010, 11:10 PM   #3
Will you be using recessed can lights? If so, what does the depth / height measure. How are you venting the exhaust / ceiing fan? Through the roof or sidewall ? The drain vents obviously need to penetrate the roof. How will you navigate those pipes?
You may find it easier to open up the existing ceiling after all. It is sooo much easier to install lights, fans, wiring, plumbing and fan venting when the ceiling is open and also to access the existing conditions
What I have done in the past is to go into the attic and pull back and pile up all the blown in insulation @ the area where the ceiling is to be removed and replace it when the new ceiling drywall is hung ( Shovel, broom, piece of scrap plywood ( about the size of a clipboard ) work just fine. You won't get every single bit, but most of it.
A lot easier from the ladder to pop your head and upper torso through the existing trusses to do all your ceiling work
Octopus is offline   Reply With Quote
The Following User Says Thank You to Octopus For This Useful Post:
ChrisDIY (12-03-2010)
Old 12-03-2010, 08:41 AM   #4
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Originally Posted by Octopus View Post
Will you be using recessed can lights? If so, what does the depth / height measure. How are you venting the exhaust / ceiling fan? Through the roof or sidewall ? The drain vents obviously need to penetrate the roof. How will you navigate those pipes?
Hall bathroom ceiling is in this thread Identification and cutting of roof truss system for skylights?
I master bathroom I haven't taken ceiling out but the bathrooms share a common "attic." I may have to pop a hole through to remove existing exhaust fan in master bath. Odd, I don't remember seeing one now that I think of it...
--Chris the DIY Guy
Old 12-03-2010, 12:17 PM   #5
Still going...
ChrisDIY's Avatar
Rewards Points: 508
Can you do the same thing for a wall. I want to turn a closet into a shower and the whole space is too large so there will be in theory a small 1' foot space between existing exterior wall and the new wall for shower. Can I leave the drywall on the current exterior wall since its holding up blow in insulation?
--Chris the DIY Guy
Old 12-03-2010, 01:37 PM   #6
joed's Avatar
yes you can
The Following User Says Thank You to joed For This Useful Post:
VERY Quick Ceiling Fan install question! Fox Electrical 11 03-23-2014 12:56 AM
Another popcorn ceiling question! HOW? Astrovel Painting 21 11-12-2010 09:19 PM
dumb question - paint ceiling or walls first tdeepness Painting 4 06-26-2010 03:00 PM
Simple question - proper direction of ceiling insulation jizzle Building & Construction 2 01-07-2009 09:08 PM
Question about ceiling joists... StlJoe Building & Construction 5 12-06-2005 11:52 AM
