Question About Doors In Basement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 12:27 AM   #1
Question about doors in basement
Hey guys,
Had a couple questions regarding doors as I'm finishing my basement. I was going to go with pre-hung doors, but I was reading some other threads about how most people recommended installing the doors after drywalling is done. Is there a reason for this or is it just preference? Is there anything wrong with installing the prehung door into my framing so I can build right around it?
Thanks!!
dstylez is offline   Reply With Quote
Old 03-06-2009, 07:07 AM   #2
Easier to cut drywall door openings before doors are installed. Easier to line up jambs after drywall installed. Depends on wether you are a door guy or a drywall guy.
Old 03-06-2009, 09:19 AM   #3
joed's Avatar
Rewards Points: 11,534
You still use prehung doors. Drywall installation is much easier if the doors are not installed. You can just drywall over the door and cut it out. Can't do that if the frame is sticking out.
Old 03-06-2009, 11:17 AM   #4
^ cool makes sense. I guess I'll get the door for measurements and to make sure my framing is right, but I just won't install it in just yet.
Old 03-07-2009, 11:06 AM   #5
Drywall contractor
Rewards Points: 1,068
Prehung is just a term to denote that the door is already in a frame, not meant to indicate hanging it prior to drywall. The "throat" on the "slip jamb" is meant to fit an opening that has the drywall installed before the door goes up........
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 03-07-2009, 01:00 PM   #6
Old School
Willie T's Avatar
Very insightful, BJ. All these years, and until you just mentioned it, it didn't dawn on me that a term like "pre-hung" could be misunderstood to mean "hung prior to".
But it sure makes sense when you think about it. Should be called "Ready to go Doors".
Willie T
Old 03-07-2009, 03:18 PM   #7
Drywall contractor
I actually never thought about it that way either until I read the post. I guess the term could be a bit misleading........
Bypass Shower Doors Install Question houston Kitchen & Bath Remodeling 4 01-31-2009 08:55 PM
Foundation & Finishing Basement Question? Taipans Remodeling 12 01-26-2009 07:56 AM
Laminate in Basement Question atilla137 Flooring 16 11-10-2007 08:44 PM
Basement Bathroom Tiling Question KUIPORNG Flooring 1 07-23-2006 12:03 AM
