Question About Cement Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-21-2010, 04:02 PM   #1
question about cement board
i am redoing my bath/shower, i am about to put up the hardy board in the shower and i have a question... which side goes out? the smooth or rough?i am putting marble tile on it after.
thanks!!
Tenchi is offline   Reply With Quote
Old 11-21-2010, 06:23 PM   #2
check the label. it should tell you which side faces out, depending on the application.
1910NE is offline   Reply With Quote
Old 11-21-2010, 09:13 PM   #3
remodeling pro
The rough side is used for thinset applications, which you should be using for a wet area. The smooth side is used for mastic, which you should not be using in a wet application.
troubleseeker is offline   Reply With Quote
question about ceiling board vs plain rock racebum Drywall & Plaster 3 06-20-2010 05:44 PM
Cement Board -- Correct Install Method? unionmaid Kitchen & Bath Remodeling 9 01-09-2010 10:04 AM
XPS foam board between basement slab and cement board for ceramic tiles jpsmith Flooring 4 02-10-2009 08:17 PM
Remove 3/4" oak floor before cement board and ceramic tile goes down?? 4just1don Flooring 8 10-31-2008 10:32 AM
Cement Board and Drywall Champy Remodeling 2 01-24-2008 03:32 PM
