-   -   question about cement board (http://www.diychatroom.com/f19/question-about-cement-board-87335/)
Tenchi 11-21-2010 04:02 PM
i am redoing my bath/shower, i am about to put up the hardy board in the shower and i have a question... which side goes out? the smooth or rough?i am putting marble tile on it after.
thanks!!
1910NE 11-21-2010 06:23 PM
check the label. it should tell you which side faces out, depending on the application.
troubleseeker 11-21-2010 09:13 PM
The rough side is used for thinset applications, which you should be using for a wet area. The smooth side is used for mastic, which you should not be using in a wet application.
