Question About Attaching Closet System To Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2013, 04:49 PM   #1
Question about attaching closet system to studs
I live in an attached townhome and am installing shelving/hanging systems in a walk-in closet. On one wall, which is about 65" from end to end, I seem to have trouble locating the studs. They don't seem to be 16" on center according to code. Furthermore, when I did find something solid (very close to a corner), it appeared that it was metal and I couldn't drill all the way through. This particular wall abuts the next unit. I have noticed that in certain spots on the outside walls elsewhere in the unit (where our unit is connected to the next) the builder has used metal studs. However, I have seen this same wall opened up a floor below (where our kitchen is being renovated) and all of those were wood studs 16" on center. Perhaps the wood was put there to screw in the kitchen cabinets, but metal studs were used upstairs.
If the wall contains metal studs and they are not 16" on center, is there still anything I can do to hang the closet system? I obviously can't hang the whole thing on drywall with anchors. It will surely come down.
Any advice would be appreciated. Thanks.
longislander2 is offline   Reply With Quote
Old 11-22-2013, 04:54 PM   #2
Rewards Points: 6,652
You could place sheets of 1/2" plywood on the wall, then attach the shelving system. Problem with steel framing, is if you do not have a good Stud finder, it will not always find them. Also that upstairs could have been framed 24" o/c. Start from the inside corner, not outside, and check for studs, by using a magnet out of a old hard drive.
Old 11-22-2013, 06:20 PM   #3
Rewards Points: 14,306
A better stud finder will find metal studs.
A cheap magnetic one will also work.
http://www.homedepot.com/p/Johnson-S...h#.Uo_0exMo7IU
Old 11-22-2013, 09:23 PM   #4
Rewards Points: 636
since it is the wall between apartments it could be double layered and or something like this for sound
http://www.clarkdietrich.com/product...-rated-systems
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 11-23-2013, 02:39 PM   #5
Thanks. I never thought of this, although we have very thick concrete walls between our units. Nevertheless, there could be a soundproof wall next to our side of the concrete since we hear absolutely nothing from our neighbors on either side.
Attaching 40-in. flat TV to metal studs? billythefish Building & Construction 24 09-27-2014 12:01 AM
Attaching wiring behind studs JohnMacc Electrical 17 02-03-2013 06:39 PM
Cast iron closet flange question madforrit Plumbing 3 10-04-2012 03:28 PM
linen closet shelves question pacifier1er Carpentry 3 06-25-2007 03:20 PM
Question about a Closet Pole limitedgoods Building & Construction 2 07-26-2006 03:42 PM
