-   -   quartz countertop problem (http://www.diychatroom.com/f19/quartz-countertop-problem-90253/)
mmmac 12-22-2010 02:49 PM
I had a quartz countertop installed 1.5 years ago through IKEA. Everything has gone great except one thing. The underlay material was not glued to the bottom of the countertop. That underlay is sagging in one place which allows one drawer to sag and rub the drawer front below it. The drawer guide is scratching the drawer front below it. I am wondering if it is OK to put a screw up into the quartz to make the counter support stay uniformly attached to the underlay and countertop. I have tried to use a construction adhesive for quartz and it doesn't seem to be working. I don't know how thick the quartz is, although I think I have enough paperwork to look that up. Any help would be appreciated.
Ron6519 12-22-2010 10:07 PM
You can not screw into the quartz without damaging it.
You need to explain exactly what counter top set up you have. If the 2 sections are delaminating you will need to find an adhesive compatible with the 2 materials and the previous adhesive.
Ron
Bud Cline 12-22-2010 10:34 PM
I am wondering if it is OK to put a screw up into the quartz...
NO NO NO !:no:
Drill a few holes in the (so-called) underlayment and squeeze 100% silicone into the holes disbursing it as much as you can between the two surfaces. Then have a clamping affair of some kind rigged and ready to immediately clamp the two materials together overnight.:yes:
This assumes I understand the problem. Never heard of a quartz countertop being done like that but - I suppose !!!:)
Ron6519 12-22-2010 11:19 PM
New product, "Quartz transformations":laughing:
Ron
Bud Cline 12-22-2010 11:22 PM
Yow well, I can guarantee they will transform their top if they go drilling holes in it.:)
stadry 12-23-2010 06:00 AM
you got the quality you paid for :( bud, forgot to send a note - will do now
Just Bill 12-23-2010 07:19 AM
Underlay material?????? I have seen lots of quartz and other man made stones tops, and none had an underlay. The top was always solid, top to bottom, same as real stone. There often was a wood insert where dishwashers screw to the top, but that is all. That was usually glued in place. Is that what you have???
Bud Cline 12-23-2010 12:45 PM
Something has just occurred to me!!!:wallbash:
For several months now I have been hearing radio advertising about a company called "Granite Transformations". One of their claims is; you don't have to remove your old countertops to have new granite countertops installed. They somehow enclose the existing tops with their product. Could that be what is happening here?:)
mmmac 12-24-2010 11:17 AM
quartz countertop problem solved
Thanks for all of the input on my countertop. I definitely won't be drilling any holes in it.
I did drill up through the underlay material and forced a construction adhesive in and tried to spread it around. After doing that on one side, It didn't seem to be holding. I found this chat room. I decided to be patient (for once) and I drilled a hole into the underlay on the other side and did the same thing. I waited an extra day and beefed up the supports pushing/clamping the two materials. After 2.5 full days of drying time, I tried putting the drawer back in and had no sagging. It seems to have done the trick.
Bud Cline 12-24-2010 06:04 PM
I wonder why you haven't told us this until now?
I suggested 100% silicone and I suggested that for a good reason over using construction adhesive. What do you suppose that reason was?:)
Pay attention 'cause this is going to be on your test next week.:)
