PVC And Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-04-2009, 06:42 PM   #1
PVC and Concrete
Are there any negative reactions that I should expect, if I run a pvc pipe in newly poured concrete? I want to allow for the passage of some drip irrigation tubing from one side of the concrete to the other and I know that caustic is a part of the equation (the concrete...not me).
bobdotcalm is offline   Reply With Quote
Old 04-04-2009, 07:49 PM   #2
Civil Engineer
Rewards Points: 4,514
I assume you have not poured the concrete yet. If you have, that is a rather different matter. PVC piping is fine in concrete, no reaction. Just make sure you bury it at least three inches below the surface so you don't get freeze damage to the thin concrete above it.
Old 04-04-2009, 08:04 PM   #3
bobdotcalm
I have not poured the concrete yet....thanks for the help.
Old 05-10-2009, 08:55 PM   #4
Household Handyman
Rewards Points: 1,408
How did this wind up in the "PC Repairs and Upgrades" section?
Old 05-12-2009, 08:59 PM   #5
I was going to ask that same thing PC. PVC. It's all the same isn't it?
PunkyPoo is offline   Reply With Quote
