Old 08-31-2009, 11:26 AM   #1
pvc coil trim use
i'm refurbishing an existing deck using composites. i'm trimming the deck out and want to use alcoa endurance pvc trim coil. has anyone ever used this product and can give me some pointers.
thanks
luapnosneb is offline   Reply With Quote
Old 09-01-2009, 07:55 PM   #2
General Contractor
pvc coil trim use
Can you give me some idea on where you will be installing the product. This might help to narrow where it will be used. If you cover any treated wood with any type of aluminum/vinyl coated coil you will find that the chemicals used to preserve the wood will cause the aluminum/vinyl to actually decay.
Deperryandassoc is offline   Reply With Quote
Old 09-02-2009, 08:55 PM   #3
pvc coil trim use
thanks, yeah i just learned that. i guess i'll be using some pvc trim sheets. i want to cover the exposed sides of my stair stringer going to my upper deck. i tried getting 1/4" thick versatex but they won't sell me 1 sheet unless they charge me $200 fee to break down a pallet load. not going to do that. i guess i'll go with 3/8" sheet and hope it's not too cumbersome to cut and install. thanks for your help.
Removing latex paint from wood trim ulbass Painting 1 03-12-2009 02:19 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Replacing a 2 ton A coil with a N coil with TX valve englewood1 HVAC 7 09-11-2008 01:09 PM
Interior Door Trim (am I the only one that does this?) javan Carpentry 17 08-14-2008 04:19 PM
Replacing all doors and trim...lots of questions... Badfish740 Carpentry 5 07-27-2008 01:16 PM
