Pvc Brick Molding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-10-2008, 09:30 PM   #1
pvc brick molding
I am replacing brick molding around an overhead garage door. I assume I nail it in. what should I use for nails?
ramies is offline   Reply With Quote
Old 07-10-2008, 10:25 PM   #2
Pre-drill all the holes with an 1/8" bit and use Hot Galvanized Finish nails of at least 2 1/2" length. Use nail set to countersink slightly.
Handyman Jim Noonan is offline   Reply With Quote
Old 07-10-2008, 10:40 PM   #3
thank you
Old 07-11-2008, 06:18 AM   #4
Licensed Contractor
For pvc molding, I use SS screws whenever possible. Fill hole with bondo, or Bond and Fill.
Renovator,LLC is offline   Reply With Quote
Old 07-11-2008, 11:59 PM   #5
i 2nd the SS theory
kylemfk is offline   Reply With Quote
Old 07-13-2008, 07:37 PM   #6
I use my 16 ga air nailer w/ 2 or 2.5" galvanized nails and caulk over the heads. Get the pressure right and you can throw your nail set away. I have installed miles of vinyl brick mold and it all looks great with no hammer dents!
The Project Guy is offline   Reply With Quote
Old 07-13-2008, 09:09 PM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
You should use what the manufacturer stipulates.
PVC materials have a greater rate of contraction and expansion than wood. Most major PVC composite brands stipulate a full-head nail, because of this.
Now, aside from that...We have always used 15g and 16g stainless steel finished nails (using pneumatic finish nail guns) to attach PVC material. We then install stainless steel trim head screws at all seams, corners, and transitions (sinking heads slightly). We have never ran into issues of material separating from the sheathing, or pulling the fastener out.
Based on that, my suggestion is to use either Stainless (always the best choice) or galvanized and caulk over the fastener (suing appropriate caulking for PVC materials).
- Build Well -
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Help with adding a strip of molding over baseboard. Bobrobert Remodeling 15 01-15-2008 11:12 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
