Putting Up Walls In Detached Building - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2012, 10:25 AM   #1
Putting up walls in detached building
I want to make a workshop/garage in a detached building. Currently the walls are simply concrete blocks with a metal isolated roof. Dimensions are about 16Wx25Lx8H. I'll mostly be using it during the winter where temperatures can get down to 0F. I'm planning on installing an electric or gas construction heater for when I'll be using it and plan on heating only when in use.
I want to put up walls of OBC boards. What would be a good way to improve isolation? Would foam boards between furring strips be sufficient? The other option would be 2x4 framing wall with Fiberglas insulation (with vapor barrier?).
frenaud is offline   Reply With Quote
Putting rigid foam on concrete walls...how to lay DriCore in this setup? ChaoticBliss Building & Construction 14 09-12-2012 05:02 PM
Can I run electrical wire BEHIND my basement walls? GoBengals Electrical 8 01-18-2012 08:38 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Info on building half walls? Gmother Building & Construction 1 10-16-2009 09:57 PM
Need to take bows out of walls. floatflyer56 Building & Construction 2 03-26-2008 02:39 PM
