Putting Up New Shield ( Drainage Problem ) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-03-2007, 12:17 PM   #1
In a few weeks I will be putting a 13' X 15' shied up, but before it goes up I need to put a base of stone for drainage under it. In heavier rains water stands under the old shield. I need to address this problem for this is where the new one is going. It is on a slight slop with a hill behind it, yes it is getting hit by 2 direction so I would like to put a 6 inch base under it.
If you can gave me some advice on how to do this it would be very helpful. :confused: :confused:
Rifeman is offline   Reply With Quote
Old 09-04-2007, 12:26 AM   #2
Unsure of the exact situation it's hard to advise. However if you have standing water sometimes under it now you may also consider in addition to gravel for drainage building the area up higher then the surrounding area? Possibley look into french drains to divert the water to a less harmfully area. I guess it all depends how far you want or need to go to solve your issue.
Mgmopar
MgMopar is offline   Reply With Quote
Old 09-04-2007, 08:18 AM   #3
I live in town and the Hill is a Old Railroad track (15 feet above my propriety) and than the street runs down hill so I have it comming down hill and accross. Only with heavy rains.
So no I cannot put it any where else but in the back.
Old 03-10-2008, 09:34 PM   #4
would this be much different,,,
than trenching around a tent when camping ?,,, worth a try - place the base elevation at what you need, build the shed, then trench around it to control the water runoff,,, just my $ .03
southernelitecr is offline   Reply With Quote
