Putting Silicone On Top Of Grout Around Bathtub - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-15-2011, 11:24 AM   #1
putting silicone on top of grout around bathtub
is it OK to put a silicone on top of grout around the bath tub?
Annushka is offline   Reply With Quote
Old 10-15-2011, 01:38 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Absolutely not!
Old 10-15-2011, 03:55 PM   #3
Bud, this is one of my (many) areas of ignorance. Would you expand on that statement some?
That's just my opinion. But it's free, so take it for what it's worth to you.
1910NE is offline   Reply With Quote
Old 10-15-2011, 03:59 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If there exists regular garden variety grout then it can be infiltrated by moisture. It must be able to breathe for any moisture to evaporate. Closing off its ability to allow for evaporation will likely grow mold under any caulk used.
Typically in junctures and any changes of plain caulk should be used, not grout. You could remove the existing grout and replace it with caulk.
The Following User Says Thank You to Bud Cline For This Useful Post:
1910NE (10-17-2011)
Old 10-16-2011, 08:49 AM   #5
Rewards Points: 5,336
Silicone what? Sealer, caulk?
Ron
B. Franklin 1759
Old 10-16-2011, 10:06 PM   #6
Too Short? Cut it Again!
Silicon is a sealant and one of the meanest things GE ever did was start convincing people it was a caulking material!
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Polyblend 'Grout Renew' - any experiences? spidrw Tiling, ceramics, marble 0 04-22-2010 12:37 PM
Grout before Caulk around bathtub? bsippl Building & Construction 6 08-19-2008 08:57 AM
Tinting/re-coloring grout proofer Flooring 7 02-02-2008 10:59 PM
Tile Grout in Bathtub drain naitek Plumbing 1 09-01-2006 07:33 AM
