Putting Rigid Foam On Concrete Walls...how To Lay DriCore In This Setup? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-22-2009, 11:23 AM   #1
Putting rigid foam on concrete walls...how to lay DriCore in this setup?
I am starting to finish my basement and I plan on putting rigid foam all long the exterior walls. I read I should seal these with tuck tape and spray foam around the edges (which I assume means top and bottom). My question is, if I plan on laying DriCore, how do I integrate it with the foam on the walls?
DriCore first and then put up the foam and seal to DriCore at bottom (or leave open and not seal)?
Foam walls first sealed to concrete floor and DriCore up to foam walls with 1/4 gap?
If anyone knows the best way, let me know.
ChaoticBliss is offline   Reply With Quote
Old 11-22-2009, 01:57 PM   #2
Remodeling Contractor
Do the walls first and seal. There are many better ways to fix the floor then dricore panels. These will simply allow the moisture to sit underneath waiting for a space to enter the flooring to deteriorate it.
Old 11-23-2009, 05:17 AM   #3
Rewards Points: 4,534
f'n amazing, bob,,, w/o doing any moisture test, he plans to o'lay a bsmt floor ? ? ? not too bright if you ask me ! ! !
we weren't meant to use bsmts as ' living space ' 'cause we don't build them for such even if blt according to code - generally the lowest acceptable standard.
& all this time i wonder'd why there are past post just f'n amazing ! ! !
Old 11-23-2009, 11:52 AM   #4
Who says I haven't done a moisture test? What's it to you anyways, I am just looking for some advice on the best way to put the walls and lay the floor.
Old 11-23-2009, 01:04 PM   #5
Registered User
Rewards Points: 5,216
Welcome to the forum! Here are two articles, you have other choices and can search topics by the same author:
From: http://www.buildingscience.com/docum...ms?full_view=1
http://www.buildingscience.com/docum...ts?full_view=1 Hope this helps!
Be safe, Gary
Old 11-23-2009, 01:07 PM   #6
w/o a moisture test, how would you know what type of floor covering/treatment would be acceptable ? ? ?
have seen too many jobs where expediency got in the way of common sense - h/o's & diy'ers relying on ' feelings ' & tv shows compared to facts,,, its your house so do what you want,,, you came looking for advice - don't take mine
have a nice thanksgiving !
Old 11-29-2009, 11:17 AM   #7
Were you ever able to figure out the proper way of installing the rigid foam on the walls and the dricore. If the dricore is laid first with a 1/4 gap against the foundation wall then the foam, the air gap would behind the rigid foam. I think the gap is only for expansion purposes. Then you can build the walls right on top of the dricore. According to the dricore website, you can use 2 inch screws to attach the wall to the dricore and then two 3 inch tapcons per 8 foot length.
Im trying to figure out the same answer, the above I got from the Holmes on Homes forum.
T.L.
ctkeebler is offline   Reply With Quote
Old 11-29-2009, 11:49 AM   #8
ccarlisle's Avatar
It's in the instructions (Figure 2.1)...foam first against the concrete, then DriCore panels up to that...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 11-29-2009, 12:41 PM   #9
I have read the instructions, I have read some debate over the question of putting/building the walls directly on top of the dricore.
Should the insulation be: foam board against concrete foundation, then the stud wall then the dricore up to the stud wall wall or should it be: dricore up to concrete wall, foam board over the dricore with stud wall on top of the dricore.
Old 11-29-2009, 12:44 PM   #10
ccarlisle's Avatar
Option II...you don't want to stud a wall directly onto concrete.
Old 11-29-2009, 04:23 PM   #11
Do I spray foam the seam where the rigid foam and dricore meet? Cut it like 1/4 or 1/2 short and then fill the gap with spray foam or can i cut it tight and seal the seal with some type of silicone caulk since the dricore is a floating system?
Old 11-30-2009, 07:10 AM   #12
ccarlisle's Avatar
Either one; depends how much room there is.
Old 09-12-2012, 04:09 PM   #13
mrtn's Avatar
Reviving an old thread becasue I'm in the middle of figuring out the same thing. My thread here Basement insulation and DRIcore
I contacted DRIcore and they told me to leave a 1/4" gap between the Rigid foam and DRIcore, then spray foam that gap. Anyone do this with good results? I think this would work but if the dricore expands and contracts will this break the sprayfoam seal?
mrtn is offline   Reply With Quote
Old 09-12-2012, 05:54 PM   #14
That is possible but usually you spray enough to compensate for such issues. Bigger issue is the foamboard against the wall. Impossible to get enough tightness to prevent moisture being trapped behind it. You need R15 tight against the concrete to prevent this (in New England zone) Which is 2" closed cell foam.
Old 09-12-2012, 06:02 PM   #15
mrtn's Avatar
You're talking spray foam now? Or 2" rigid xps?
Drywall over 1-1.5" rigid foam? michael76 Drywall & Plaster 23 05-22-2011 04:07 AM
fiberglass over rigid foam board in cantilever? KatieAK Building & Construction 3 11-17-2009 08:48 PM
Insulating Foam *under* concrete basement floor? nilsca Building & Construction 2 03-20-2009 07:58 PM
Best way to smooth concrete before putting down floor? Tommy2 Flooring 9 12-24-2008 09:15 AM
Best Ext. Sheathing: Rigid Foam An Option? austinbirdman Building & Construction 3 12-15-2006 10:02 AM
