Putting New T1-11 On A Garage. Can I Just Attach It To The Old Siding? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 02:34 PM   #1
Putting new t1-11 on a garage. Can I just attach it to the old siding?
I am looking to put up new T1-11 to replace the sides of a detached garage (750 sqft) as the plywood siding on it is beginning ot deteriorate.
A friend of mine told me to cut the bottom 6", check for termite damage and then either attached the T1-11 directly to the drywall through to the studs. I was going to put a layer of caulk between the too as a moisture barrier. the detached garage is built like a shed, but with a concrete floor.
bjmarchini is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 03:56 PM
new double garage murray1426 Building & Construction 4 05-23-2009 01:11 PM
Help putting an internal door through to the garage from the hall vix92008 Building & Construction 4 02-17-2005 12:46 PM
