Old 04-20-2008, 01:15 PM   #1
Post
putting light fixtures into support beams
I have a breakfast nook in which i want to add three pendant lights to. The problem is, i would need to drill three holes through the support beam, from the attic. Is this a problem? Will it weaken the structure too much?
bobbineye is offline   Reply With Quote
Old 04-20-2008, 05:16 PM   #2
Average Joe/ex-Navy IC3
gregzoll's Avatar
What do you think?
gregzoll is online now   Reply With Quote
Old 04-20-2008, 06:44 PM   #3
nap
You talking to me?
nap's Avatar
it depends on a lot of things. It is a tough call when one cannot view the situation and must depend on verbal explanation only.
depending on what your support beam actually is will make the difference. if you explain the structure a bit, maybe somebody will be able to help a bit more.
Old 04-20-2008, 09:15 PM   #4
Moderator
Termite's Avatar
Yes, please elaborate on the beam, or posting a pic would be just as good.
Vertical holes are ok in certain types of beams in certain situations, and are absolute no-no's in other types.
New outdoor light fixtures? Yeti Remodeling 3 02-27-2008 12:34 PM
Replacing support beams Annimal76 Remodeling 1 09-10-2007 11:12 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
where to get support beams elementx440 Building & Construction 5 03-21-2007 06:19 PM
