Old 12-14-2012, 01:08 PM   #121
Putting in header in wall!
UPDATE: guess what guys?
we went ahead and cut it open! pictures to come. it's crazy!
federer is offline   Reply With Quote
The Following User Says Thank You to federer For This Useful Post:
oh'mike (12-14-2012)
Old 12-14-2012, 05:02 PM   #122
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Now this sounds interesting. Bring on the pics!
123pugsy is offline   Reply With Quote
The Following User Says Thank You to 123pugsy For This Useful Post:
federer (12-14-2012)
Old 12-14-2012, 07:10 PM   #123
prepping: we secured 2x4s to the rafter before cutting it down
Old 12-14-2012, 07:14 PM   #124
taking out the 2nd stud the rafter is nailed to:
Old 12-14-2012, 07:15 PM   #125
rafters with the studs gone! this is where the opening is going into. time for header!
Old 12-14-2012, 07:18 PM   #126
header time! the rafters were cut down precisely with circular saw to be flush with the opening in the wall. we used 2x10 with plywood in the middle to get the right width. then metal brackets were screwed to secure. opening is just under 4ft wide, 6ft tall. 2x4 jack studs at each end of opening
Old 12-14-2012, 07:22 PM   #127
finished project! you can see also we nailed new 2x4s to the other studs that the rafters are connected to. (you can kind of see that the rafters are sistered to old 2x4s. so the new studs we put in are actually direct under each rafter cut flush for the rafter to sit on top of) total we took out 2 studs only. over a week later it looks fine!
Old 12-14-2012, 07:44 PM   #128
by the way i want to thank everyone who came in and took a look and offered their advice. it was greatly appreciated. basically it came down to my stubborn brother who said 'f*ck it i wanna do it" so thats how that went. what do you guys think!
Old 12-14-2012, 11:30 PM   #129
no comments???
Old 12-15-2012, 08:47 AM   #130
Moderator
kwikfishron's Avatar
Fender there’s so many things wrong there I don’t know where to start.
Your biggest mistake was not following the advice of many here to hire a design professional or at least a competent contractor to do an onsite inspection and help you develop a workable plan.
It’s still not to late to do that.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
federer (12-15-2012), mae-ling (12-19-2012)
Old 12-15-2012, 12:53 PM   #131
can you just pick out one thing that you feel like addressing? i know there is a lot going on. so any one specific thing would help!
Old 12-15-2012, 04:46 PM   #132
123pugsy's Avatar
i know. so from what you see, what plan would you draft? thanks
A structural engineer would probably be a good part of the plan.
I believe you are waiting for an answer from someone that says, "add a piece there" or something to that effect. I doubt anyone will give you the answer you want to hear.
Old 12-15-2012, 04:59 PM   #133
thanks for your reply. yea no i am not expecting that. this whole thread has been such good advice, and everyones said it needs a proper look at. its just that we dont have the funds to do it. all the engineers we called wants $500 just to take a look, then more $ to give us a plan. so thats why i am here.
edit-we actually did spend money for 2 enginners to come out. they both said it was possible. one even gave us a drawing. if you guys really want i can try to post his drawing here. it that helps you guys.
Old 12-15-2012, 05:01 PM   #134
i guess a better question for you guys is this:
"what in the picture is the problem that jumps out at you"? is it the rafters? the size of teh opening? the metal braces? the material used? maybe this would help narrow things down to the most essential things to deal with
Old 12-18-2012, 11:31 PM   #135
Moderator
Two things I notice; pp.38, Fig.19; The hangered rafters are bearing in the hanger on the wrong edge for proper support. With enough load the hanger will split the rafter down the center because the hanger is not supporting the heel, which is why it is against code. On your thread page 6 picture, another problem is the ceiling joists appear to be higher up than in the lower 1/3 of rise from plate to ridge board, the rafters may be under-sized for the span/load, also; Fig 21. Are they in the upper 1/3 as in Fig.22? Pages 38-39:http://books.google.com/books?id=iwS...joists&f=false
Gary
PS. you could add a 4x4 in the crotch above the ceiling joist where the rafters have bearing in your latest pics, to help keep the rafters from splitting under snow loads. Add more nails at the ceiling joist/rafter connection.
Clothes taking longer to dry?
The Following User Says Thank You to Gary in WA For This Useful Post:
federer (12-19-2012)
Avoiding load on inner, exterior wall jklingel Building & Construction 2 06-04-2011 02:35 PM
Bearing wall header size gtimk4 Building & Construction 4 08-05-2010 12:34 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
