Old 01-17-2010, 11:17 AM   #1
Landlord
Putting in a closet to make a bonus room into a bedroom
I'm picking one corner and it will be probably about 3x3 feet or standard with the rest of my small closets. Should I tear down the drywall to the studs where the closet is going or just start laying out the framing on top of the existing drywall?
cocean is offline   Reply With Quote
Old 01-17-2010, 11:43 AM   #2
Landlord
Couple more questions. Do I need pressure treated lumber on the concrete slab floor with the sill gasket foam underneath it? There is an electrical panel in the room....I suppose that it is not wise to closet around that is it?
Old 01-17-2010, 11:51 AM   #3
Xtreme DIY'r
An electric panel can't be in a clothes closet
There must be 30" of clear space side to side & 3' clear in front of the panel at all times
Build the closet over exisitng sheetrock
You want the outside wall to remain sealed
I use PT against concrete, I did use the sill foam in my garage
Old 01-17-2010, 11:55 AM   #4
Landlord
So, just frame it out, and but up new drywall to the existing walls and ceiling??
Old 01-17-2010, 11:57 AM   #5
Xtreme DIY'r
Yes, that is what I would do
Its a good idea for the 1st 2x4 coming out from the wall to be nailed into a 2x4 that is in the existing wall
Old 01-17-2010, 12:07 PM   #6
Dave - for clarification, it's not the clearance requirements that would be the problem for this closet, it's that the clothing and flamable items - correct? So even if the clearance requirement is met - a closets is still a no-go for electric panels.
Vince
Old 01-17-2010, 12:13 PM   #7
Yes, treated lumber wherever resting on concrete - typically no foam sealant needed under interior wall. Go right over and up against the existing drywall. Placing the new walls where they meet the ceiling and walls to something nailable is a good thing.
Old 01-17-2010, 12:15 PM   #8
Xtreme DIY'r
Yes, a panel can't be in a clothes closet - that is the issue
So even with clearances it can't be done
Old 01-17-2010, 12:20 PM   #9
Landlord
OK, forget about the panel, I kind of already knew the answer to that. I'm going to go with the other corner. Any rules about how close the closet door can be to a window?
Old 01-17-2010, 12:22 PM   #10
Xtreme DIY'r
Not as far as I know
Just make sure the door knob won't hit the window
Old 01-17-2010, 12:22 PM   #11
Landlord
Man, I hate this stud finder. Is there a good stud finder out there that anyone personally uses?
Old 01-17-2010, 01:58 PM   #12
I went through a couple three until I found one that worked pretty well. Have had it a few years - is by Zircon and similar to this one at HD.
http://www.homedepot.com/Tools-Hardw...atalogId=10053
Old 01-17-2010, 07:50 PM   #13
Moderator
Build the framing properly. Pull some drywall and add studs or blocking in the walls or ceiling for the new walls. Pages 30 and 36, at the bottoms:
http://www.awc.org/pdf/WCD1-300.pdf Do quality, professional work, you'll be glad you did.
Doors and windows don't mix. The window or the person usually loses in an accident. Doors near windows need to meet minimum safety requirements. If you were to ignore these or be misinformed and had a claim, your insurance carrier could easily deny monies. http://docs.google.com/viewer?a=v&q=...HPbWWaP6zwY0fg Notice number 6.
http://books.google.com/books?id=TT8...rances&f=false
Be safe, Gary
Clothes taking longer to dry?
Annexing service closet former33t Building & Construction 1 01-13-2008 02:29 PM
Carpet in Bonus Room dorag40 Flooring 1 12-04-2007 10:46 PM
will putting too much oil in a car make it smoke from the exhaust / drive weird? joeyboy Automotive Repairs 4 09-28-2007 07:53 AM
