Pump Jacks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-23-2011, 09:36 PM   #1
Maryland
Pump jacks
I'm in the planning/permit phase of re-siding our house. House is balloon framed with wood clapboards nailed directly to the studs. The clapboards are rotting, so we'll be removing them in sections and applying OSB sheathing and tyvek.
The highest point of the gables is approximately 32 feet. I'm exploring my options for scaling the side of the house and so far, pump jacks seem to offer the best combination of safety, cost and ease of use. (Personally I would feel more comfortable on scaffolding, but the cost is ridiculous.) Having never used pump jacks, I'm a bit confused by the system. It appears as though aluminum poles are preferred to wooden ones; however, I can only find aluminum poles in 24' lengths. (Werner) These won't cut the mustard as I need to be able to reach the peak of the gables. Can someone with experience chime in and offer some insight? Can the poles be joined together to achieve more height?
Pittsville is offline   Reply With Quote
Old 06-23-2011, 09:43 PM   #2
KemoSabe
loneframer's Avatar
I use Alum-A-Pole pump jacks. The 24' poles are kind of standard, but I have bought 12' poles and splices to add to the length. You can also get 6's and 18's.
http://www.industrialladder.com/prod...categoryID=245
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
The Following User Says Thank You to loneframer For This Useful Post:
thomasjmarino (06-25-2011)
Old 06-24-2011, 12:26 AM   #3
Maryland
Thanks for the info! The aluminum system looks fantastic, but very pricey. Looks like I might have to go with steel pump jacks and wooden poles. Should be sufficient for the couple of weeks spent re-siding the house.
Old 06-24-2011, 06:40 AM   #4
KemoSabe
loneframer's Avatar
I've worked off of both. There is no way I'd go up on wood poles and steel jacks again. I'm not saying they aren't safe, but I am saying they aren't as nice as aluminum. Then again, I still have 9 aluminum poles at my disposal.
If you don't go with aluminum poles, at least get aluminum walk planks to use.
The Following 3 Users Say Thank You to loneframer For This Useful Post:
kwikfishron (06-24-2011), rossfingal (06-24-2011), thomasjmarino (06-25-2011)
Old 06-24-2011, 07:02 AM   #5
Rewards Points: 2,238
I've made 28 foot pump-jack poles by ripping 2 x 4's out of 28 foot
Douglas Fir, 2 X 8's.
Very strong - very little "flex" - very heavy.
Be careful after you have them set up - on soil + rain - the bottom
can sink.
We put pieces of 2 X 10 or 2 X 12 under the base.
Good luck!
Also, as "loneframer" states - aluminum planks!
You should be able to rent them.
rossfingal
rossfingal is offline   Reply With Quote
Old 06-24-2011, 07:09 AM   #6
kwikfishron's Avatar
Rewards Points: 86
You can rent Alum-A-Poles.
kwikfishron is online now   Reply With Quote
The Following 2 Users Say Thank You to kwikfishron For This Useful Post:
thomasjmarino (06-25-2011), Tom Struble (06-24-2011)
Old 06-24-2011, 03:01 PM   #7
Tizzer's Avatar
Rewards Points: 452
Have you priced "renting" scaffolding? Rent what you need to get up to the second floor, then stack to get up into the gable.
With pump jacks, you'll need a ladder to get yourself up on the roof to nail the brackets on with a couple buddies helping to push the pole up to you.
How steep is the roof?
30ft. up is no place to play if you've never used them before. Get the widest plank you can fit. Probably could use a buddy up there to help hoist a 4X8 sheet of OSB up unless you're the He Man type.
Tizzer is offline   Reply With Quote
Old 06-24-2011, 04:26 PM   #8
Maryland
The only place locally that rents scaffolding wants $260 a DAY for what equates to a 5 wide x 7 long x 30 high tower. I can buy the same size tower for around $1400. So basically, if I use the scaffolding for more than 5 days (which I will be) it makes the most sense to buy. I know that the scaffolding is a lot more labor intensive than the pump jacks, but the more I think about it, the more comfortable I think I'll be at 30 feet on scaffolding. And to me, that security is worth the extra labor/cost. Thanks for all of the feedback!
Old 06-24-2011, 06:50 PM   #9
KemoSabe
loneframer's Avatar
It's only my opinion, but it sounds like you're going to need more than a single tower of scaffolding. How long is the house? How many floors?
I've hung literally thousands of sheets of sheathing off of pump jacks. Scaffolding is going to be a PITA.
Two poles will run you about 1200 bucks, another 800 or so for a couple walk planks.
When you are done, they will easily sell for 1400, so you pay 600 to use them as long as you need to. That's cheap rent if it takes you all Summer.
Old 06-24-2011, 06:52 PM   #10
KemoSabe
loneframer's Avatar
Oh, depending on where you live, I'll rent you 3 of mine for the Summer.
Old 06-24-2011, 07:22 PM   #11
Rewards Points: 86
Scaffolding being a PITA is almost an understatement.
There will be almost as much work involved dealing it than the work itself.
If you can’t swing the aluminum pole system you’d be better off with wood poles than staging. You can use wood poles up to 30’ in length, keep in mind though that you have to brace to the wall every 10’. The aluminum system you only brace to the wall every 25’.
With either system be sure to get the workbench holder with the jacks. You can use an extension ladder for the bench.
Old 06-24-2011, 08:00 PM   #12
KemoSabe
loneframer's Avatar
If you go with the wood pole system be sure to get the workbench holder with the jacks. You can use an extension ladder for the bench.
Excellent advice.
Old 06-25-2011, 03:59 AM   #13
Maryland
How safe are the aluminum pump jack systems? I have zero experience, but would obviously use the guard rails and workbench. For some reason, I think I'd feel comfortable pumping up, but not cranking down.
House faces are 25', 25', 70' and 70'. So I would need 3+ poles per side.
Old 06-25-2011, 06:36 AM   #14
KemoSabe
loneframer's Avatar
I'd set up the 70' sides with 4 poles and 3 24' pics. The pumps are very safe. I've worked on them on and off for the last 14 years. They need to be set up properly, but aside from that, carelessness of the user is the only real danger. Pay attention to where you are and you are golden.
I recommend using planks with interlocking handles that the safety chain can be ran through so the planks don't overlap each other. Not all planks are built this way. Never do it with planks having plastic handles.
Old 06-25-2011, 08:14 AM   #15
Rewards Points: 86
The system itself is safe, the user on the other hand is a different story.
I would never want anyone on the plank with me if they weren’t comfortable being up there.
The poles “do” move around, there "is" swaying. When your holding that sheet against the wall the plank will push back some. The further away the jack is from the ground and the brace the more it moves. No big deal for me, it’s second nature but for some the movement is absolutely terrifying.
Which guy are you?
30’ is a long way up there and having 2 people (I assume you’ll have help) with no experience on the plank could be dangerous. Dropping a sheet of plywood (or anything else) from that high is unacceptable.
Not everything is DIY.
I’ll give you one tip on cranking down. Make sure the pump pedal is all the way in the up position before kicking out the release pedal to go down. If you don’t when you kick out the one the other will come flying back up at you (ouch), and the jack will drop a few inches instantly (it's pretty loud too).
You’ll probably only do that once though.
The Following User Says Thank You to kwikfishron For This Useful Post:
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
Pump Jacks MrBdo Building & Construction 1 01-03-2009 01:52 PM
