Pump Jack Installation Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2011, 09:36 PM   #1
Mr. Handy
Rewards Points: 16
I have a house that I need to reside the gables. The problem I have is that there is a overhang/soffit just below the gables. The peak of the gable is @ 32 feet from the ground. How can I get the pump jacks and stages above/past this overhang/soffit?
swiederin is offline   Reply With Quote
Old 08-04-2011, 09:54 PM   #2
AGWhitehouse's Avatar
The usually have stand-offs that hold the poles off the building. Are these overhangs larger than normal? I've seen the poles work on overhangs up to 2'-0". They may have stand-offs for larger, but i've personally never seen them in use.
Life's too short...so enjoy it!
AGWhitehouse is offline   Reply With Quote
Old 08-05-2011, 05:18 AM   #3
kwikfishron's Avatar
Rewards Points: 432
If I’m understanding you correctly as you go up the wall there’s a roof overhang in the way and more siding above that?
If so those can be tricky to set up for sometimes. I wouldn’t even try to comment on how you should do it without some pictures first.
Are the poles aluminum or wood?
kwikfishron is online now   Reply With Quote
Old 08-05-2011, 06:12 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
lay the pump jacks on the ground and pump the jacks up to where they will be above the roof apron when stood up. then install the arms at the top of the poles and then raise the pumps into position, ( you will need a hand on raising the pump jacks). then secure the arms to the house. you might have to pull the bottom of the poles away from the house to keep the poles from hitting the apron or gutter below.
Old 08-05-2011, 06:54 AM   #5
Rewards Points: 432
There’s easier ways to go about it too. My first choice is not to stand a 30’ pole with the jack at 20’. What if the main roof is to steep to walk?
I just feel more comfortable seeing the wall before advising rookie DIY scaffold set up 30’ in the air.
Old 08-05-2011, 11:40 AM   #6
buletbob's Avatar
If the roof is to steep then they have to be fastened from an extension ladder, same as setting the planks. if the poster has this equipment ,then I feel he is confident to assume this task. other wise let a licensed contractor perform this work.
when ever a home owner decides to perform any work on there house the they must also assume the risks involved. I can only answer the question that was asked. the choice is up to him if he feels confident enough to perform this job. NO sarcasm intended.
Old 08-06-2011, 06:13 PM   #7
Mr. Handy
Rewards Points: 16
My biggest concern is getting the stages up there.
Old 08-06-2011, 06:44 PM   #8
Rewards Points: 432
Don’t you have any help? If you’re not confident with what you’re doing then you should find someone that is.
I don’t know what obstacles you may or may not be dealing with like electrical service, trees, steep slopes, fence in the way, the neighbors dog.
Post some pictures and I’ll tell you how I’d do it or wait for the ones with crystal balls and they can help.
Old 08-07-2011, 06:38 AM   #9
Mr. Handy
Rewards Points: 16
Gable Image
Here is an image of what I need to deal with. The soffit is @ 22 feet from the ground.
Old 08-07-2011, 06:59 AM   #10
Rewards Points: 432
I don’t really see what the problem is. Once your poles are braced off the upper roof the jacks and plank will clear that overhang. You just set everything up as normal and jack up to that area. Just don’t set the poles to far apart or you won’t be able to reach the top.
Old 08-07-2011, 07:12 AM   #11
buletbob's Avatar
the stages must be carried up from extension ladders. its a two person job, one ladder at each end of pole one person on each ladder carrying up the plank to set on pumps. done deal.
The Following User Says Thank You to buletbob For This Useful Post:
kwikfishron (08-07-2011)
Old 08-07-2011, 07:29 AM   #12
Rewards Points: 432
Ya what he said, my eyeballs aren’t quite working yet this morning?
That wall looked cantilevered to me.
Old 08-07-2011, 08:15 AM   #13
Tom Struble's Avatar
Rewards Points: 2,002
how wide are the stages?need a new pic better showing the differences in overhang depth
looks to me you will be able to pump a 12'' stage past that
may need to pull the gutter
can you get me a pic of that gable? looks like a nice shake detail
Tom Struble is offline   Reply With Quote
Heat Pump will not cut off sunliner HVAC 13 05-17-2011 05:38 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 04:35 PM
Sump pump large draw of power BlueBSH Electrical 1 03-16-2011 10:51 AM
utility sink pump installation rcassidy Plumbing 1 02-17-2009 09:34 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 04:35 PM
