Pull Up Bar - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-12-2013, 01:17 PM   #1
Pull Up Bar
Will 3 - 16" on center 2"x4" wall studs support 600 pounds when anchored 32" apart. I want to set up a pull up bar in my garage strong enough to support 2 people simultaneously. The plan is to anchor 3 steel rectangles, which will have the pull-up bar 30" of the wall, with the load spread between every other stud. I plan to use 3 lag bolts per vertical support.
bobsperti is offline   Reply With Quote
Old 04-12-2013, 01:57 PM   #2
"You can do anything"-Mom
brockmiera's Avatar
There are other variables needed in order to know. Do you have a picture of the area? how far from the support wall will this pull up bar be located? The vertical force is important but so is the distance away from your support wall Torque = force x moment arm.
brockmiera is offline   Reply With Quote
Snow Blower Pull doesn't have tension Camper147 Tools 17 02-03-2015 08:52 AM
connect a pull chain switch to a click switch on pendant light. davesobel Electrical 2 02-15-2012 08:52 AM
Rewire, pull old wire, or leave it. rrunkle Electrical 6 01-31-2012 12:40 PM
Corner Tape coming up, do i have to pull all down. caseynshan2 Painting 1 11-25-2011 01:00 PM
Installing a pull chain ceiling fixture safron Electrical 16 08-22-2011 06:13 PM
