Ptw Rim Joist = Composite Fascia Board - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-14-2010, 11:00 AM   #1
ptw Rim joist = composite fascia board
Hi everyone,
I'm planning my deck and trying to figure out if I can use a fascia board of the same material as the deck (trex accent saddle) as the rim joist. I understand that the rim joist helps tie all the 2x10 joist together so I'm wondering if I need to use wood instead of the composite. I quess the wood is thicker then the composite. Maybe I should use wood as the rim joist then cover the ptw with the composite? I wondering what the industry standard might be. Any help would be appreciate.
max_wonder00 is offline   Reply With Quote
Old 10-14-2010, 11:59 AM   #2
kwikfishron's Avatar
Rewards Points: 594
Use the PT for the rim then wrap that in 1x Trex if you want. You can not use Trex in the framing.
Since your still in the planning stages for your Trex Deck you might want to take a look at this.
http://www.diychatroom.com/f19/trex-...ointing-10043/
kwikfishron is offline   Reply With Quote
Old 10-14-2010, 12:51 PM   #3
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
Yep, PT 2x10's all the way around and then trim of your choice on top of that. I am in the final stages of my deck and the 2x10's will be clad w/ 1x12's of cedar like the decking.
CoconutPete is offline   Reply With Quote
Old 10-15-2010, 07:05 PM   #4
Thanks Pete and Kwikfishron, for your answers. I apreciate being able to ask a simple question and getting good feedback
Tags
rim joist fascia board
Jacking and Sistering Floor Joist Captain.Sassy Building & Construction 17 08-11-2010 01:30 PM
Deck - Header Joist Repair w/ pics DawnMarie Building & Construction 3 06-14-2010 08:25 PM
Space between joist and beam on deck schveiguy Building & Construction 11 09-08-2009 09:15 AM
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
